Pre Cat deletes/J-Pipes/Test pipes/Down-pipes WHAT?!?!?!
#41
practicing nihilist
if you keep any of the stock parts in line, you're restricting that portion to 2.25" via a 2.5" aftermarket pipe. Not efficient. It keep the tone down but it won't be breathing as good as it could be.
#42
Green Machine
Hey guys, a few questions:
1.Is the High Flow Cat much quieter compared to the test pipe?
2.I understand that the test pipe and race pipe are very similar, but I'm just wondering if it is worth the money to go for a HFC instead of a test pipe?
3.Also, how much do test pipes generally run for?
4. Best brands for HFC's or Test pipes?
Thanks!!
Thanks!!
2. The test pipe will give you more flow than any cat whether HFC or stock. It depends on if you want to go catless or not. You could also find a use Eshift 3rd Procats cheaper than ATLP or RV6. But you will have to port the outlet from 2.25" to 2.5" to fit an aftermarket exhaust.
3. You can find a use one for around $60 or less.
4. As mention in #2, ATLP, RV6, or Eshift with minor mod. RV6 for test pipe.
I had Procats, RV6 test/j-pipe, and stock catback. I had lots of low and mid range power, but topend sucked. If you can live with that, go for it. You will still have better performance that stock regardless.
#46
I would recommend starting with the mid-muffler delete because having that mid-muffler will uhmmm... "muffle" the sound of your exhaust mods. This is the only exhaust mod that you can't DIY because a muffler shop will need to weld in a section of pipe. All other exhaust mods you can easily do yourself with basic hand tools.
Next I would recommend the j-pipe because the j-pipe offers the biggest gains.
Next would be the 3rd cat delete.
#48
athomas214,
You got it right. If you plan to do the catback, then I would recommend the following -
If you are more interested in the sound, do the catback first.
If you are more interested in performance, do the j-pipe first.
#51
well no i dont plan on keeping my third cat, thats what the race pipe is for. I assume the mid-muffler your talking about is the resonator on the catback? which in my case would be left on because I wanted to keep my cat-back stock.
Basically im trying to get the most bang for my buck with my exhaust. Since aftermarket cat-back is so expensive i figured i would just go with precat deletes, j-pipe, and racepipe. but your telling me that wont be effective because of the stock cat-back. correct?
#53
Chapter Leader (San Antonio)
AcuraTLparts.com
heeltoeauto.com
http://www.heeltoeauto.com/product.p...cat=668&page=1
#54
TL = True Love
i have a question that im stuck with after reading the previous posts, i'm thinking about doing the exact same thing come tax returns . I have the mid muffler delete and know that the pipe is 2.25" will buying the test pipe and j-pipe fit the stock exhaust with the supplies that it comes with? In other words does the connection between the test pipe and catback have same dimensions when screwing in.
#55
3rd Gear
Do you have any videos of your car? Im trying to get all that stuff but first i want to see how it sounds. Thans
#58
Just ordered RV6 pre cat deletes, have RV6 V3 j-pipe and XLR8 exhaust
I really want a turbo is there a turbo manifold, will I be able to keep the RV6 pre cat deletes for a turbo still?
#59
Acura tl type s 2007
Look into RV6 perfomance parts, merc racing for superchargers and turbos and get a Hondata Flashpro before doing these upgrades and all your parts will get the full horsepower they can push. I have a guy that is a amazing tuner who helps me out on all this.
#60
Hondata Flashpro
If you have a guy that is great at tining cars. Go with XLR8 exhaust quad tips RV6 perfomance j-pipe, PCD- pre cat delete if the pre cat delete is legal in your state, and definitely get the Hondata Flashpro to get all the HP out of those products and cold air intake. You will be close to 350hp by then.
navtool.com
31
11-16-2015 08:30 PM
