PowerStop Rotor
Old Jun 20, 2011 | 01:56 AM
mnm27mnm's Avatar
PowerStop Rotor
Hi guys, i just received my PowerStop Rotors and on one of them there's like a stain on the bottom right, u can see in the picture. Is this normal? Will it come off once it gets some wear? Thanks in advanced.
Old Jun 20, 2011 | 02:26 AM
paperboy42190's Avatar
looks fine to me, it should come off, probably just some grease when packaging the product
Old Jun 20, 2011 | 07:30 AM
Comptechtl2367's Avatar
Use so brake clean and clean the rotor before you put it on. if it does not come off when you use that i am sure it will with wear.
Old Jun 20, 2011 | 09:47 PM
TLove It!'s Avatar
Superstressed
X2^ Also, I just did mine tonight and they were Power Stop also, they look and stop nice. FYI DEFINITELY use an IMPACT screw driver on the phillips screws that hold your rotors on.
Old Jun 20, 2011 | 10:14 PM
mnm27mnm's Avatar
can it be just a strong power drill? or does it have to be a impact driver?
Old Jun 20, 2011 | 11:08 PM
TLove It!'s Avatar
Superstressed
I'd go with the impact fur sure. Be sure to spray those fukn things with penatrating oil and also try to have an Easy Out or Left Handed Drill Bit ready Just n case. No not justnspace. LOL! Where is that guy? I can't believe he hasn't jumped in here yet.
Seriously though try to have this stuff on hand, I had to borrow it from a friend. GL
Old Jun 20, 2011 | 11:33 PM
mnm27mnm's Avatar
ok thanks, I'll find a way to take it off. I'm going to go spray it down with dw-40 right now, so i can change them either tomorrow or wednesday. since im going to paint the calipers red since i have to take the rotors off, minues well do it all at once. I have the car lifted already with front tires off, now i just need to find time.
Old Jun 21, 2011 | 08:27 AM
av2600's Avatar
try to clean it, if not i'm sure it will come off with use. mine had a stain on them too, i wasnt worried about it
Old Jun 21, 2011 | 10:43 PM
emas's Avatar
not trying bogart your thread.... but has anyone had experience on using these brake packages yet, and how do they compare to the OEM??
Old Jun 22, 2011 | 12:37 AM
4play's Avatar
mine will not come out at all to install my extended studs. i've read that some people just drill em out and you never need them again. i've also heard that you can heat the area around it with a torch to expand the metal, but you gotta be careful not to heat the wheel bearing too much.
Old Jun 22, 2011 | 10:43 AM
Timeless's Avatar
OP, the stain is nothing to worry about. Clean it with brake cleaner if you want, but it won't harm anything.
The little rotor retaining screws will almost definitely strip when you try to remove them. I know first hand even when using the impact driver.
Don't bother using a torch, if the screws strip, drill them out and don't look back. The retaining screws are a cute idea but otherwise pretty useless.
Old Jul 30, 2012 | 09:54 PM
FarS's Avatar
Guys what tools do i need besides Impac SDriver to remove the calipers and rotors? Do i need Wrench Allen Key? what size?
Old Jul 30, 2012 | 11:03 PM
anx1300c's Avatar
No allen wrenches involved. I forget the bolt sizes, but if you have basic metric sockets, you'll be fine. This is the impact I use. Never any problems if I hit the screws with PB Blaster and let it sit for 20 minutes.
http://www.sears.com/craftsman-impac...p-00947641000P
Old Jul 31, 2012 | 08:30 PM
SSM4DR's Avatar
I bought the same tool as pictured above when I changed my rotors to power slot slotted ones. And that tool was awesome, all my screws came off nicely without any damage whatsoever.
Old Aug 1, 2012 | 03:38 PM
FarS's Avatar
ill definetely going to get this imp sdriver. Another question ab the rotors,
I'm looking into eline R1-Concept rotors. Can't decide between "cross drilled and slotted" or just "cross drilled". I've read many feedbacks stating that slots may cause shaking but than I read a few more, some people state that drilled holes causing shaking because air gets into it. I'm really confused which ones to get. But i know for sure slots =better stoping, drilled holes = less heat. My idea is to put cross drilled in front to reduce the heat that way i can extend pads life and plain ones in the back. Right now I'm runing on stock and I already replaced my front pads but rears still have more than 75%.
Is that true that holes causing shaking at the high speeds? I don't really want to feel any shaking on my car. It will definetely harm the braking performance.
Old Aug 1, 2012 | 03:41 PM
Originally Posted by tlove it!
i'd go with the impact fur sure. Be sure to spray those fukn things with penatrating oil and also try to have an easy out or left handed drill bit ready just n case. no not justnspace. Lol! Where is that guy? i can't believe he hasn't jumped in here yet.
Seriously though try to have this stuff on hand, i had to borrow it from a friend. Gl
lmao!!!!!
Old Aug 1, 2012 | 09:15 PM
FarS's Avatar
Sorry for bothering that much but from my understanding torque wrench is a must when replacing the rotors isn't it? they come in different sizing 1/2 and 3/8 which one i'm suppose to get ?
Old Aug 1, 2012 | 11:59 PM
anx1300c's Avatar
No.
Old Aug 2, 2012 | 01:25 AM
A SiQ TL's Avatar
unless you want to torque your lug nuts to factory specs so you don't warp the new rotors.
although, I don't know if aftermarket rotors will warp from that, or if it's just the oem ones that will
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
