Painting AEM Tube
Painting AEM Tube
Has anyone had success with painting their AEM Tube. If so, what paint did you use and what was the process. I'm thinking of painting mine a glossy black to match the engine bay. Currently have the blue one. Please post pics.
CTS-V Import Slayer
Painting over anodizing will be problematic. You will need to make sure the surface is properly etched and prepared to accept the paint before you spray. I might even suggest, other than buying another one that is black already, sanding all the anodizing off before you proceed...but may still be problematic. You might think about taking it to a good powder coater and see what they think?
Walk the walk
You do not have to etch anodized aluminum before you paint it. I just happen to be extremely familiar with aluminum, anodizing and painting from actual detail design on these type of components on current commercial and military aircraft. I am well familiar with MIL-A-8625. You should use a primer and then paint with paint suitable for the underhood temperature environment. I'm sure automotive engine paint will be fine. It is SOP to paint ONLY anodized or iridited MIL-C-5541 aluminum never bare. Although for a automotive application the environment is somewhat less demanding than a F-18 E/F you would be fine. However, since you have some corrosion prevention scheme on the existing tube it would illogical to remove it. You would be amazed what primer does. If you told someone in the industry that you were going to etch anodized aluminum prior to painting they would be quite puzzled.
CTS-V Import Slayer
So you are saying it is cool just to prime and paint...right over anodizing and it will be all good...right? I have several parts that are anodized around my garage from my motorcycle....that I would really rather have painted....so just a regular primer and a paint with heat tollerance is good and all I really need? No need for all the hub-bub that I was thinking I was going to have to go though? I was figuring on having to have these parts powder coated in order to get them the color I wanted.....this is very good for me!
I order a red AEM CAI and used 600 grit paper to scuff off the anodized red paint and then painted it with semi-gloss black high temp header paint. Hope that helps you out. Might be able to post a picture up soon.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
