Oversized brakes
Oversized brakes
Does anyone make oversized rotters for the 3G tl. I have seen some bbk but I'm looking to go that route right now. If not I guess I will just buy the stage 1 kit from healtoe. I just have a big empty space in there with my 19inch wheels
Former Sponsor
If you want larger rotors you want a Big Brake Kit. I'd highly recommend STOPTECH's BBK:
http://store.excelerateperformance.c.../i-210334.aspx
If you want upgraded rotors and pads check out our XLR8 Brake Packages:
Base TL Auto Brake Package:
http://store.excelerateperformance.c.../i-304785.aspx
TL with Brembo Calipers Package:
http://store.excelerateperformance.c.../i-304786.aspx
These Acurazine brake packages are designed to improve braking performance and durability at a reasonable price. The packages include Powerslot/STOPTECH performance rotors and STOPTECH Performance pads. All of the rotors have a black e-coating on the hubs and vanes and an advanced alloy composition. The Powerslot slotted rotors for the front of most Acuras also have a Power Alloy composition and a curved vane construction, which helps reduce heat in the brake system. The STOPTECH Performance pads are a para-aramid compound, which has great initial bite and long-term performance and lower dust and noise than most aftermarket brake pads.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
