Oil In intake manifold
Old 05-03-2016, 07:25 AM
07tltypes6spd's Avatar
Just got my car back from tuning and the guy told me i have oil in my intake manifold and throttle body because of a bad pcv? I have recently put on the j37 intake manifold and throttle body. Anyone else have this issue and find any idea where the pcv is? thank in advance 07 acura tl type s.
Old 05-03-2016, 01:04 PM
no one has a answer?
Old 05-03-2016, 01:16 PM
Received 16,263 Likes on 11,973 Posts
the pcv is on the manifold.
if you look directly at the engine bay
firewall
engine
radiator
it will be on the left hand side, near the powersteering pump on the manifold.
its okay to have some oil and debris in the manifold, as PCV is doing its job!
Old 05-03-2016, 04:49 PM
crbnfbr's Avatar
Also, look up oil catch can or occ. It keeps the oil from going back into the manifold.
EvilVirus (05-04-2016)
Old 05-04-2016, 07:03 AM
thisaznboi88's Avatar
firewall
engine
radiator
PCV is on the valve cover. The front valve cover with 1 10mm bolt.
The following 2 users liked this post by thisaznboi88:
EvilVirus (05-04-2016), justnspace (05-04-2016)
Old 05-04-2016, 07:07 AM
^can you tell I havent worked on my car in a long long time??lol
Old 05-04-2016, 07:10 AM
it is okay it happens
Old 05-04-2016, 04:45 PM
yeh i thought that was it, I know there should be oil in there but i think i have way to much going in. Only reason is because everytime you start it after it sits for a hour or longer it dumps a lot of smoke. I took the throttle body off and everything was drenched in oil. I think im gonna take the oil catch can approach.
Old 05-04-2016, 04:49 PM
does anyone have a write up on doing a oil catch can?
Old 05-04-2016, 04:56 PM
csmeance's Avatar
Received 2,004 Likes on 1,424 Posts
That's something I've only seen on german cars when the valve-stem seals go bad! Is it a small puff of white smoke?
Old 05-04-2016, 05:05 PM
Ill try to make one when I do mine. I have an ebay catch can that I got for cheap cheap.
here is a DIY that a member made.
Oil Catch Can - DIY - Honda Accord Forum : V6 Performance Accord Forums
Old 05-04-2016, 06:23 PM
Gadgetmanconnor's Avatar
I agree with it being PCV. I had the same issue on my S2000 except being catless, I just had oil blow-by residue on my bumper and sure enough I pulled the intake and there was oil. Pulled my pcv soaked it in brake cleaner and shook it up and it stopped.
I'm not sure about new-er cars but the older PCV valves basically had a small ball in it and if you cleaned it and could rattle it, it was good.
Old 05-04-2016, 08:33 PM
crbnfbr's Avatar
My OCC gets less than a tablespoons worth of oil in it after 10k miles. So, it doesn't catch much.
Old 05-04-2016, 08:43 PM
crbnfbr's Avatar
https://acurazine.com/forums/third-g...arator-926287/
Or, google "husky oil catch can"
Old 05-04-2016, 09:12 PM
BigJHouse's Avatar
I used the husky for 10k dumped it one time and it will be going back on.
Old 05-05-2016, 12:19 PM
its a big cloud of smoke when first started and running after that but goes away after 5-10 minutes I'm gonna change the pcv valve and put in a occ. pcv is just one bolt and it comes right out?
Old 01-14-2017, 11:08 AM
4drturbo's Avatar
Going to use my Bwoody unit for my TL-S from my SRT-4. It worked great. Just need to verify that the size of the current barb that is installed will work for the TL. Don't want a bottleneck in my PCV system.
Universal Oil Catch Can, PT Cruiser GT | BWP Automotive Concepts.
I will do a write up since all the oil catch can how-tos have broken pictures.
Anyone know the diameter of the PCV line on the TL?
acura_dipset_tl
04-26-2016 11:50 AM
3g tl beast
17
02-25-2016 07:34 PM
PrimeTimeTSA
02-21-2016 10:06 AM
6spd-GERCO
22
02-16-2016 07:56 PM
TheTLProject
15
02-10-2016 10:45 AM
Quick Reply: Oil In intake manifold
