Now what?
Old Jul 12, 2008 | 11:19 PM
brownpakistud08's Avatar
"Tantalizing Lilin"
Now what?
After installing my fujita cai, p2r tb spacer, e-cutouts and jpipe (had one now have to get another one...) i have run out of ideas on what to do to in terms of gainin performance. i really want a supercharger but dont have that money. is there anything else i could do to squeeze more hp out of the engine?
Old Jul 12, 2008 | 11:21 PM
WRXtranceformed's Avatar
#ForcedInductionFamily
Old Jul 12, 2008 | 11:26 PM
Bearcat94's Avatar
AZ Community Team
Pulley?
Cat Back Exhaust (or do the e-cutouts bypass the exhaust??)?
Old Jul 12, 2008 | 11:27 PM
"Tantalizing Lilin"
aahhh nitrous oxide something id loooovee to get except im scared id probably blow up my car....out of curiosity, how much wud a NOS kit be to get installed?
Old Jul 12, 2008 | 11:29 PM
"Tantalizing Lilin"
Originally Posted by Bearcat94
Pulley?
ecutouts do bypass the exhaust, i have them installed right after the 3rd cat so basically its a free flowing exhausts. i dont know much about the pulleys but i do know there are two types...which one wud be better for me if im not looking to replace all my belts and such?
Old Jul 13, 2008 | 12:10 AM
TLAdvanced's Avatar
The Kinetics of Bleu
Originally Posted by WRXtranceformed
Fake nitrous canister bass tube, how would that
help performance??
Old Jul 13, 2008 | 12:24 AM
Bearcat94's Avatar
AZ Community Team
Stock size.
Supposed to free up, say, 5 - 8 WHP.
Light Weight Wheels? ~15 - 18 pounds.
Race Springs and Performance Shocks or Coil-Overs to hold those Wheels to the ground better (you're probably already lowered though)? HP doesn't do you much good if you're spinning your tires.
Old Jul 13, 2008 | 12:49 AM
"Tantalizing Lilin"
im lowered on aspec suspension idk much abt suspension but car grips fine, wheels dont spin ever, i did tho replace stock michelins for all season performance tires ..wheels im looking into just need to save a little bit more but if the pulleys arent too expensive, i mite have to look into them more..where would i buy them btw?
Old Jul 13, 2008 | 01:21 AM
csmeance's Avatar
Stock size.
The pulley persay won't give you 5-8 WHP on the dyno, but what will happen is that the car will rev up faster, meaning speed is gained faster. This gain in speed is simple converted into a WHP number, so the car becomes as fast as if you added 5-8 WHP.
Old Jul 13, 2008 | 01:25 AM
csmeance's Avatar
How about:
Intake Manifold spacer
ATLP Exhaust
ATLP Test pipe
E-Shift Pro cats/high flow cats
Port and Polish (P2R makes ones done already)
UR Underdrive or Stock size pulley
Seafoam Cleansing
Rear Sway Bar for better handling
Lightweight battery
Weight Reduction (remove spare, rear mats, etc.)
If you plan on getting the SC, then it would be best for you to buy the UR Stock Lightweight pulley, you can buy them from excelerate in the black market section. You can buy the ATLP parts from acuratlparts.com
Old Jul 13, 2008 | 01:42 AM
"Tantalizing Lilin"
ahh thanks for the info ill look into all of these things. supercharger wont be for at least 1-2 years but i will def look into gettin the pulleys asap
Old Jul 13, 2008 | 09:03 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
dont forget r-v6 precat deletes
Old Jul 13, 2008 | 10:26 AM
01tl4tl's Avatar
you only need the crankshaft pulley- not any of the other ones
Its several pounds lighter than the stock one- get the stock size if buying 1 belt for $45 is going to break your budget on a 200$ part, OR if you run 600++++ watts stereo at full blast at idle as part of your normal life, stay stock size in lightweight crank pulley.
The underdrive pulley runs the ac compressor slower- just slightly- but enough to reduce parasitic drag by a substancial amount. The slight slowing to the ps pump does not hurt the steering or anything else, its the alternator at idle- and huge stereo potential load- thats why there is a caution.
Old Jul 13, 2008 | 01:51 PM
"Tantalizing Lilin"
haha i would love to except i wont be able to pass emissions...unless u kno a way around that??
Old Jul 13, 2008 | 02:18 PM
JCL622's Avatar
A-spec steering wheel ftw
you're in MO i'm pretty sure they hook it up to the OBDII input; they dont take the stupid tester to the rear of the car anymore, tho if you don't somehow mask the syrup smell i guess that's a dead give away.
Old Jul 13, 2008 | 03:02 PM
csmeance's Avatar
get emmisions done then switch out to the precats...
Old Jul 13, 2008 | 04:00 PM
"Tantalizing Lilin"
dont i have to pass emissions every year though?? i soo dont kno how emisions work..unles i can find me a 'hookup' for emissions
