New Rotors from Marcus at Heeltoe...
Spoke to Marcus yesterday regarding new Rotors and pads for my TL-S and he told me he is working with RacingBrake to develop a one piece rotor specifically for our cars with Brembos... Seemed very excited about the project and said they will be comparable in price to the one piece non-Brembo that Racingbrake offers.... Still for the best of the best the two piece Racingbrake rotor in his opinion is the way to go..... Good luck Marcus and let us know when they will be rolled out...
Full of water...
Full of water...
I can never make up my mind with the 1pc vs 2pc rotors. Higher initial cost, less replacement cost with the 2pc.
2pc transfer less heat into the hub and bearing area. However, the hub and rim acts as a heatsink and should run slighly cooler with the 1pc.
The real claim to fame with the 2 pc rotors is the lack of distortion at high temperatures. Since the friction area is not rigidly connected to the hub area, there is little distortion under high heat conditions. It's said 1pc rotors try and distort into a cone shape.
I went with the 1pc since I have never run into any issues with this and I've turned the rotors blue and faded the brakes completely. My pads have always worn evenly and the car has been tracked on sticky tires so I can't see ever needing more than 1pc. The exception would be much higher hp levels and running slicks.
The RB 2-piece w/ ET300 pads is exactly the setup I was planning to run....Thanks for input...made my decision easy. Princelybug, do you also run ET300's on the rears?
I have the RB 2pc w/ ET500, 6MT
Generally no noise, very quite braking. Now, if I do a heavy brake from 40-50mph+ to 0mph I will hear a slight noise, but nothing of any concern what so ever. I have to turn the radio off as well since it is not loud, it's no where near an "awful" sound. Just sounds like the brakes doing what they're suppose to do, again only on a heavy high speed brake to 0mph. For all I know, my OEM's might have been making the same noise, but I don't remember. I'm completely satisfied with my RB stuff from Heal Toe.
Under construction
One on the right for me
My set-up does not squeal at all. Any squealing should be fix-able. I had infrequent squeals at first, but I was able to eliminate with re-lubing the caliper better, also with a different synth. brake lube. It was Versa Chem lubricant I think.
from my conversation with marcus about a week ago, he said they were in development with Racing Brake. I would expect a mid summer release....I'll shoot him a note today and see what he thinks...
FYI
From RacingBrake......
Yes, it's being tooled up and we expect to have them ready for shipment in 12-14 weeks. We are also developing a matching big brake kit for the rear for a better balanced brake for stock (282x12mm) upgrade.
Hello, I understand from Marcus at HeelToe that you are working on a 1 piece rotor for TL's with Brembo front calipers....can you tell me when you think they may be available? thanks
Chapter Leader (Central Florida)
Interesting indeed.... this seems like its right up my alley.
However I have always wondered why no one has come out with a kit to increase the size of the rotors with our stock calipers. I mean why not come out with a 13.5-14" rotor that simply uses a bracket to space the caliper? The Brembo calipers on our cars are beefy enough that I simply cannot fathom spending the money for a BBK from another manufacturer just for an extra inch or two of rotor....
Did you fade the brakes with the RB 1 piece? What pads were you using? What about the fluid? I'm assuming this was on the track...hope there was some good run off!
I've only had my two piece with the ET500 pads for just over a week now and no noise so far. I have a 6MT with the Brembos.
I was just saying that I think the main advantage of the 2pc is not so much performance but durability through extreme heat cycles. I didn't have a problem with distortion on with my stock brakes so hopefully I won't with the 1pc larger brakes. The larger diamter may make them more prone to distortion but so far so good.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
