New Prank J-series Intake
Old 02-21-2015 | 01:14 PM
yungone501's Avatar
J-series addict
Prototype High Clearance Intake Manifold ? Prank Parts
Old 02-21-2015 | 01:23 PM
N1h1l1ty's Avatar
Confusing Name Guy
Wait is this applicable to a 3G TL?
Old 02-21-2015 | 01:44 PM
polobunny's Avatar
Registered Bunny
The new Prank Parts High Clearance Intake Manifold is a limited run of only 6 hand made intake manifolds that gain hood clearance with j series engines and saves 7 pounds over the stock j32a2 intake manifold
Guess.
Old 02-21-2015 | 01:53 PM
N1h1l1ty's Avatar
Confusing Name Guy
Sorry I should rephrase - Why exactly would one get this for a j32a3 TL. From the phrasing I sort of assumed this was geared towards J-swapped builds. Would there be a hp advantage here like a 3.7 im swap?
I get that you're looking at a weight reduction and increased clearance, but if I remember correctly we've never had hood clearance issues with the 3.7 swap or otherwise. If I'm missing something obvious please enlighten me
Old 02-21-2015 | 01:54 PM
yungone501's Avatar
J-series addict
If the height clears the fuel rails and injectors, it very well could be used. Even if not, a spacer could be used. Obviously the IMRC valve would have to be removed, you will probably need a throttle body adapter to run your stock TB and the EGR port shapes will need to be blended to match between the lower runners and the manifold if I'm not mistaken...I believe the j32a2 has oval ports and the j32a3 are round.
Old 02-21-2015 | 01:58 PM
N1h1l1ty's Avatar
Confusing Name Guy
^ So the answer is "not without some work / troubleshooting". I'm going to imagine the 3.7 swap is more worthwhile if clearance issues are not a concern
Old 02-21-2015 | 02:03 PM
yungone501's Avatar
J-series addict
I don't think anyone ever mentioned a reason for you to buy this. This is a j-series specific forum and the manifold is a custom part that may help someone else. Leave it at that and let others be enlightened. No disrespect.
Old 02-21-2015 | 02:07 PM
anx1300c's Avatar
The throttle body will obviously be situated further back in the engine bay, so major CAI changes will be necessary. And of course, that's going to cause clearance issues with the fuse box and strut bar. It can still be made to work I bet.
Any dynos on this? Looks like a solid piece.
Old 02-21-2015 | 02:13 PM
N1h1l1ty's Avatar
Confusing Name Guy
Yung I'm not sure if you read my post as confrontational or if I'm doing so with your post but I genuinely was curious as to a reason to buy one, seeing as I was looking at a 3.7 swap and this came up - I didn't mean it in a "wtf would you buy this" way and im sorry if you read it as such...
yungone501 (02-21-2015)
Old 02-21-2015 | 02:20 PM
brian6speed's Avatar
Lone Wolf
Probably only worth buying if you have hood clearance issues in a j-swapped vehicle.
On the J32a2 you can actually mod the OEM IM to make more power than the 3.7 IM with a 76 MM TB.
The 3.7 IM weighs around 10 lbs less, but has less power potential. Still not sure which I will run, have both.
Old 02-21-2015 | 02:24 PM
Lone Wolf
The lower IM ports are the same for the j32a2, j32a3, and j37. The EGR port is slightly different though. Gasket for either car should work. You are probably thinking of the runner to head ports.
Old 02-21-2015 | 02:31 PM
yungone501's Avatar
J-series addict
My first thought when seeing the intake was it had numerous advantages from the tubular style runners and the equal air/pressure distribution plenum. This could allow for much better air/fuel mixture into all chambers not to mention simple wet port nitrous installation and/or meth injection setups. This long runner design will also improve low end torque production if the correct math was done in the length and size of the tubing.
Old 02-21-2015 | 02:33 PM
yungone501's Avatar
J-series addict
To clarify, I meant the EGR port only, not the intake ports.
Old 02-21-2015 | 02:38 PM
Lone Wolf
Hard to say without dyno comparisons. I would be surprised if any ever get posted. Someone can be the guinee pig. Seems more suited for drag cars since it won't clear a strut bar. Are you interested in trying it over your custom setup?
Prank Parts owner is on this forum. Username is pinkBatman, you could PM him. He is very friendly.
Was thinking that might be what you mean. You can just leave the egr alone and run the j32a2, j32a3, or j37 gaskets. They all should work. I would go with the j32a3 or j37 myself.
Old 02-23-2015 | 04:30 PM
314_04TL's Avatar
DAAAAAMN!!! thats sexy
Old 02-23-2015 | 10:20 PM
teh CL's Avatar
Wow that's nice..
Old 02-26-2015 | 10:18 PM
yungone501's Avatar
J-series addict
How's this for extreme clearance purposes?
Old 02-27-2015 | 07:01 AM
Lone Wolf
What is that off? Is it plastic composite? The IM for my Focus ST is plastic composite. Very light and whole IM only costs 60 bucks to replace.
Old 02-27-2015 | 07:38 AM
yungone501's Avatar
J-series addict
Honda marine outboard engine.
Old 02-28-2015 | 09:14 AM
simione's Avatar
$699 for mild steel?
Old 02-28-2015 | 11:40 AM
yungone501's Avatar
J-series addict
Lmao. Yeah and also the intake relies on oil from the PCV system to coat the inside preventing rust. Pshhhh, what?!
Old 02-28-2015 | 04:23 PM
teh CL's Avatar
That would def go well with the J35 spacer for hood clearance..
Old 03-01-2015 | 01:40 PM
Lone Wolf
Just ship it to Swaintech and get outside and inside coated.
Old 03-01-2015 | 07:25 PM
thisaznboi88's Avatar
^ +2 on swaintech coating. White lighting FTW
Old 03-02-2015 | 05:44 PM
jiga21's Avatar
shit looks sick af, my egr has been turned off since flashpro no worries. The piece def catches my attention, but i like my strut bar intact. Good find op! That steel would cause MAJOR HEAT SOAK too, something a lil meth cant fix...hmmmm
Old 03-02-2015 | 09:29 PM
yungone501's Avatar
J-series addict
Found this the other night. I believe the guy that is building this is associated with the whole "Prank Parts" name.
Old 03-03-2015 | 06:23 AM
jiga21's Avatar
Is it me or do the runners appear a lot smaller than they do on prankwebsite link u posted ?
Old 03-03-2015 | 10:11 AM
Lone Wolf
The gaps between pipes do look larger.
Old 03-03-2015 | 12:21 PM
probably couldn't get the socket in to tighten it down on the rear side.
Old 03-03-2015 | 10:10 PM
yungone501's Avatar
J-series addict
Hey what about this work of art here:
jiga21 (03-05-2015)
Old 03-20-2015 | 12:28 AM
PinkBatman's Avatar
7th Gear
Heyevery one, it's me! I found this thread while looking at my site traffic, so I'm a little late. I'm not going quote too many posts, just answer some of the other questions I saw.
These are indeed made for swap cars, you can try it on your native J cars if you would like, but without numbers I'm sure you wouldn't want to risk it, especially with all your hood clearance.
These are made of mild steel for a few reasons, cost, build time, and strength are big ones. Heat soak has never been a problem on my car, I get ambient air temps pretty consistently and my intake hardly ever gets warm.
That black intake is indeed mine, and the runners are smaller on that one. 1.75" compared to 1.88 on the ones listed on the site.
Here is a customers car with the intake in Jamaica that the owner modified to accept a nitrous kit.
Old 03-20-2015 | 08:25 PM
yungone501's Avatar
J-series addict
Mil-spec harness looks good. Who is your supplier on materials for these?
Btw, your build was looking good. Still in progress? Last I read, you were doing some crazy Fit j-swap.
Old 04-01-2015 | 10:18 PM
PinkBatman's Avatar
7th Gear
My harness was done by ChaseBays, If I had to do it again I would get it done by Tuck Tech, that dude is big in the J scene and does killer work
I'm planning to part out my EG sedan and use that money to really finish the Fit.
Old 04-05-2015 | 04:41 PM
j32a2racing's Avatar
9th Gear
I'm getting a tune with this manifold on in 2 days I can let you know how that works out
Old 04-06-2015 | 09:27 AM
240sx acura tech's Avatar
acura master tech
in this for the tune numbers
Old 04-06-2015 | 09:31 AM
9th Gear
The build is a j32a2 LSD cl-s trans, prank intake mani bored to 90mm, 90mm skunk2 tb & thermal gaskets, UR light weight crank pulley, 4" intake, 3" strait pipe exhaust. Its going to be tuned tomorrow at 1pm.
Old 04-06-2015 | 10:16 AM
Lone Wolf
Nice. Yea post up results. I personally wouldn't go that big for tb.
yungone501 (04-06-2015)
Old 04-07-2015 | 05:49 PM
9th Gear
Technical difficulties with the aem ecu not being compatible with a non auto j motor
Old 04-07-2015 | 05:51 PM
9th Gear
So im hoping next week i can get on the dyno
Old 04-07-2015 | 06:21 PM
Lone Wolf
Yea you would have been better off buying auto motor.
I actually have a tuckteck custom harness to run aem ems and all the gears/sensors to swap to auto. Will sell it.
Other option is this.
Dezod Motorsports. Dezod Motorsports AEM EMS Standalone Engine Management System-CL Type S 01-03 6 Speed
Dezod uses the AEM 30-6050, but they don't divulge what they had to modify.
Quick Reply: New Prank J-series Intake
