MDX cams in '04 base
Old 01-05-2014 | 05:43 PM
BigJHouse's Avatar
Will the mdx cams work with the stock valve train? 04 base 6 speed with 96k
Old 01-05-2014 | 08:55 PM
thisaznboi88's Avatar
What year? Might be the same as your tl unless your talking about 09 mdx camshaft
Old 01-05-2014 | 10:54 PM
GRAF-FITI's Avatar
what is the benefit to this?
Old 01-05-2014 | 11:45 PM
BigJHouse's Avatar
The 09 mdx cams are lighter than the type s cams with the same profile
Old 01-06-2014 | 08:19 AM
kingkong_dav's Avatar
KingKong_Dav
Some engine builders go with the RL cams. better specs than the type S
Old 01-06-2014 | 11:03 AM
BigJHouse's Avatar
I was looking at the rl cams too but I didn't see that much of a difference for the cost but I also do not know a lot about cams. If anyone with better knowledge could help that would be great and what about my stock springs and retainers will they hold up to the new can?
Old 01-07-2014 | 06:37 PM
Scottwax's Avatar
Mr. Detail
What supporting mods do you have? Its always best to chose a cam that works well with everything else you've done.
Old 01-07-2014 | 08:53 PM
Grand_hustle17's Avatar
Cams as a 1st mod?..... This is a 1st
Old 01-08-2014 | 10:10 AM
BigJHouse's Avatar
I was going to do the cams while I'm in there doing a valve adjustment I have a couple things planned for February. Just making sure the 09 mdx cams will be fine with my valvetrain
Old 01-21-2014 | 02:17 PM
fsttyms1's Avatar
I have the Hollow (09 i believe) MDX cams in my 2nd gen TL Heads. I had to make 2 shims for the cam gears to sit at the proper distance but other than that it was a direct fit.
Old 02-06-2014 | 10:37 AM
eclypse's Avatar
i just did ported, polished, 3 angled heads and backcut valves as a first, haha. but i was doing a 150k mile refresh for my wife's car. couldnt let myself leave it alone.
i check every week on whether or not there's cam options for this car, but it seems the answers so far have been
* Omgerd I installed da new cam and much faster very VTEC (no dyno before/after)
* I installed type-s, and gained nothing
* I installed type-s and gained top end
* BISMOTO cams are off on their timing (I_love_cars)
* you'd have to create your own custom cam gear and cams to get this job done in any remotely worthwhile manner
The last option there hasnt been proven wrong, yet.
Old 02-06-2014 | 12:10 PM
mzilvar's Avatar
ILC did a custom stage 3 grind from web not bisimoto I know Andy was running bisi cams not sure if he had any problems but seemed like he had it running well on I think it was stage 2 bisi cams
If you go with a regrind look into wpc treating them afterwards I've been told its worth every penny and will harden the cams some more after the regrind and rehardening
I've been told a good rule of thumb with regrinds is to keep the exhaust duration within 10 degrees of the intake
Old 02-06-2014 | 10:05 PM
KingKong_Dav
Bisimoto is webcams.
Old 02-06-2014 | 10:08 PM
KingKong_Dav
Gude performance makes one for the j series but most likey goes through webcams too.
Old 02-07-2014 | 12:06 AM
mzilvar's Avatar
True, different profile though.
mlody
12-04-2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: MDX cams in '04 base
