Ls swap TL
#41
I am not saying that its not do able due to funds (spent 15k on my Civic and 18k on my 240sx before i was 22 (all money i earned myself!)) but it just does not make any sense to throw that kind of money into this car. You would have to cut out the trunk floor and restructure the rear end and then cut the tunnel out and rebuild a new rear sus. thats if you want to go RWD. Then for FWD you will have to fully re configure you front sus, and sub frame, along with most likely frame rails. Also throw in there hood issues, core support issues and wiring. Not worth it at all for a FWD car. Build a strocker and throw on a turbo, once you out grow that or are sick of throwing all that money away on a FWD car then you can upgrade to a Vette or 350z ect.
#42
#43
Registered Member
I wish people on here would actually discuss the idea instead of shooting it down so fast. Anything is possible with the proper design, skill and the right amount of money.
OP, I have gone over this in my head hundreds of times and spent countless hours looking at different parts from different vehicles on what might actually work. My dad is a lead design engineer for GM and has been helping with ideas.
If the LSX series engine will fit there are several considerations for the the engine bay first. The engine would have to be set as far back as possible which could cause the firewall to have to be reworked in order to clear the rear of the engine and allow access to the 2 rear cylinders. The oil pan would have to be shortened and clearanced to keep it up high enough and out of harms way. Perhaps like the FD RX7 guys are doing with their LSX swaps. Hood clearance will be a problem towards the front cylinders of the car since our front end slopes downward.
You would have to build a tunnel under the center console and radio in order to clear the transmission. Also you will have to take into consideration the location of the shifter (either auto or manual) The T56 6spd sits a little far back. The 4L60E might be a better option to solve this issue.
Then we still have to figure out the front suspension and the rear end.
Try contacting Hinson Super Cars and see what ideas they have. They are working on a V8 conversion kit for the S2000 right now.
#44
Good guys (Tony & Kenny very friendly), but GT-Rs & Supras are their big thing, not the TL.
#46
DANSOLOW
Thanks man, I'll look into it!
#47
#48
Registered Member
I shot it down right away because you would have to be crazy to try to do this and spend the same amount of money as the car was selling for new (base) to make it RWD with a V8. I helped a friend do an s2k swap in a Del Sol which is a much easier car to cut apart and mod (that and they are worth nothing so if you screw up getting a new one is cheap) and it still took over 2 years to complete and then all said and done you have a Del Sol that you sunk 10-20k into and you would be lucky to sell it for 8-10. Sorry to be so negitave but all you talked about was fitment, not suspension, rear end, wiring, engine management, gauge setup, fuel (your axle is now where your tank was), or dash. If some even managed to get the motor in, the car will never look good inside because the dash would be back, you would have to move the front seats back and then have no back seat, in a 4 door car... I feel like people who have these ideas dont think about everything, its would be sweet but just buy a G8 if you want a 4dr with a RWD v8. You compaired the swap to two RWD cars (RX7/S2K), the V8 swap in both is 20x easier.
I would love to own a G8 but since Pontiac is no more there are a limited number. I like the way my TL looks and don't want another car. But I would love RWD. We do these things because we love our cars. If we wanted something different we would have bought it instead.
#52
ElectroMechanicalEngineer
Here is an example of a similar project and the amount of work you would have to do. This guy spent a better part of over 4 years doing this...
http://www.honda-tech.com/showthread.php?t=981613
#53
Chapter Leader (San Antonio)
If nobody discussed these ideas than you wouldn't have that turbo. Its because we discuss these things that people are willing to try and find the solution. For engine managament if you are running a stock LSX than all you need is the computer. Send it out and have the VATS disabled and you are done. Keep the stock computer in place to maintain all of the luxury items like you do with the J&R computer. Wiring- Painless will build you a harness for anything so that is not an issue either. The front seats should not have to be moved back. There is plenty of room behind the dash to keep that in place. Not sure why you think the dash has to be moved. Have you seen how bulky it is? A possible solution for a rear end would be the Cobra IRS. 62" width just like the TL. For a fuel tank the 4th gen TL one could be an option.
Kickazz spent about 25-30k on a Turbo with everything for about 600WHP.
You're going to spend double that to do this AND not get 600WHP. And you don't even know what would happen down the line! Now for 50-60k I'd rather buy a M3 or C63 AMG or an other car to avoid the hassle.
#54
Lol, a turbo for the car or full swap with a LS engine AND making it RWD is a COMPLETE total different animal we're talking about.
:w hat::wha t:
#55
#56
DANSOLOW
I'm gonna try and email some companies soon and see what they say and check out ls1tech.. If something comes up I'll be sure to inform everyone:..
#57
Registered Member
#58
This whole thread is a bunch of what ifs and well maybe. Once someone can show that this could be done and can show that they have the know how to do it then it can be a serious topic. Even then i would still say your throwing your money (A fuc* ton of it) away but i would give huge props to the person who did it.
#67
DANSOLOW
xsilverhawkx
09-28-2015 06:51 PM
