Looking for Moarrr Roarrrr
My fellow Acura owners...I love you all for being so helpful all the time!!
Ok so I already have the magnaflow catback (mufflers, tips, resonator) and a mid muffler delete. But iv grown accustomed to the sound and I want to make it ROARRRR MOARRRR
Any suggestions? Will the rv6 J pipe add much to the sound?
What about the hfpcd's?
Much appreciated as always!
Any pipe upgrades will alter the sound of the exhaust. If you are looking for a lower tone, J pipe will add that. PCDs will give a raspier sound because they are straight pipes. HFPCs will give a nice growl but wont give off as much rasp as the PCDs. Check out some youtube videos of exhausts and use those to base your decisions.
Each Jpipe will give you a different sound. It won't sound worlds different and probably won't add any 'volume' to the sound, but it will give it a different tone. The PCDs will definitely make it much louder and 'aggressive,' but will come with rasp, especially with no mid muffler. The HFPCs will add volume to the exhaust too, but with less rasp than the PCDs because they have cats.
Thanks for all the responses guys, very helpful stuff!
I dont want to swap out my current setup. I really like how aggressive it looks with the 3.5 inch tips. Just want more roar on acceleration.
From the info it sounds like the hfpcs is my best bet for a deeper tone when I accelerate.
^^ This. I misread, you only the mufflers and resonator? Get some 2.5 or 3" piping to replace your stock diameter piping for more roar. Your 'staged' exhaust isn't giving you much rumble.
That shouldn't cost much more. Which ones better 2.5' or 3'?
How wide is the stock piping?
The whole point of a tuned exhaust is to allow optimum scavenging. To do this you need as much velocity as possible. Now velocity does not mean a 4" pipe, for example your water hose, when it's fully open it pours out slowly and if you cover half of it with your finger the speed increases.
So think of it like this, the pcds are 2.25 inches since we have two that is 2.25X2 which equals 4.5". This has been proven to be optimum under most J30 applications. As the speed slows a smaller pipe is needed to keep the pulses going quickly, this is when the single 3" comes in. That is a 1.5" decrease in size. As you go to the dual exhaust you could have pretty small pipping and it shouldn't hurt power, but at the same time it's so far back in the exhaust the size you have won't really hurt anything (in theory, if I have this wrong please correct it)
You misunderstood what I was saying. The two pcds piping added together is 4.5 inches. They come together to a 2.5in collector and then to a 3 or 2.5 mid pipe. I'd say a 3in is good for i/e mods and 2.5 for little things. The dual piping can be any size really. However someone dynoed and the best results were with 2.5,but honestly that had to of been a error because that's more than the 2 pcds added together. However I would choose the dual 2.5 just for looks.
I did some searching for the whole back pressure problem. Found this old excerpt from user 'i hate cars.'
Needing back pressure is a myth. It's even more of a myth when you consider the car is on the small cam during most of your 60'. Only 2-strokes and rotaries need back pressure.
Usually eliminating back pressure boosts the midrange and upper rpms more making the low end feel weak when in reality it is not.
Scavenging should not be real important since it's a vtec car and the exhaust ports are merged inside of the heads. You could try the Supertrap muffler for adjustable backpressure for testing lol. I wonder if they still make those. For a street car, you should be able to chop the exhaust off right at the heads and not see a loss of torque.
Roarrrrrrrrrrrrrrrrrrr.
You can't just add the pipe diameters together. You have to get the internal volume of a 3" pipe and the internal volume of a 2.25" pipe. You then multiply that by 2 to compare to the 3" pipes volume. Dual 2.25s is only slightly larger than a single 3" if I remember correctly. So in essence, you should still have a 'venturi' effect going from dual 2.25" PCDs/Jpipe to a single 3".
If you are only doing it for sound, just get a 2.5" exhaust.
To properly scavenge, you are going to want a Jpipe with a 3" collector as well. Otherwise, I'd recommend 2.5".
