J32A2 head swap and true dual exhaust build
#41
Must have a helluva job, no girlfriend, live at home, or all of the above. Lol
Good shit man!
Good shit man!
gerzand (08-19-2013)
gerzand (08-22-2013)
#45
gerzand (08-20-2013)
#47
Thought you had the bottom end built... didn't know you only had ARPs. And you have been spraying it this whole time.
#49
Hmm.. wondering now if I should spray or not on my j30... 50-100 shot hmm.
But first I got to finishy ecu conversion
#51
Lol. Just grab some lotion, a box of tissues, and youtube search 'gerzand'.
#54
I had the opportunity to not only see and hear Andy's car this weekend but to DRIVE it . Not only does it sound awesome, the power is incredible. I don't even think i got into VTEC in his car but it still pulls wayyyy harder than mine (obviously). Andy is a J Series pioneer. The nitrous pull he took me on was completely exhilarating!
#56
gerzand (08-25-2013)
#58
How does the A2 flow compared to the A8?
A3s ported flow about the same as the A8s, right?
#61
The intake side is about identical @ 300-310CFM with hand porting by comparing 2 shops work. The A2 exhaust side (obviously) has benefits, but I dont have hard numbers there, because this little shop in Georgia ahem *KMS* ahem wont respond to my emails and give me the flow datasheet I paid for. Someone want to haggle him for me? John Kauffman is the name.
#62
Haha, Andy's finally dropping some names.
You should have your headers replicated. Where do they end and meet with the exhaust? Where the stock cats normally do or did you wrap them under a bit more?
#63
They meet right at the oil pan mating surface. There is 1/8" clearance between the subframe and the front header 3" v-band clamp so they're super tight to install. They have a significantly longer merge than any other headers and stiff 75a motor mounts are necessary. I'd classify them as mid length. Long tube headers on an A2 head swap aren't possible in this car due to the motor mount placement and the need to remove the motor if you wanted that sort of setup on this chassis
#64
Great info man. Thanks!
#65
#66
Well if so this will be the second time I've gotten lied to by separate shops. He did provide some software screenshots while flowing but no hard numbers, such as mid lift cfms on intake or exhaust at ALL. I'll be calling my bank today. The work looked good...and I took before and after measurements throughout the ports but the fact is I need the numbers.
#67
They probably are improved. The 3.7 gets into some pretty insane piston speeds. I wish Honda would come out with a new block that allowed a larger bore and shorter stroke. At 7,200rpm the J37 has a mean piston speed of 23m/sec while the J32 is only at 20.6m/sec. Are all of these rods the same length/interchangeable?
JJH (09-04-2013)
#68
#69
They are interchangable as long as youre using the necessary matched (displacement not P/N) crank as well. This is because all rod lengths are different j30 vs j32 vs j35 vs j37.
Yes, a j32a2 swapped turbo civic on stock internals put down 700whp for 30 pulls at the strip before throwing a rod. His thread is over at j32a. He ended up just swapping another junkyard motor in for likely $500-1000 and is is running again I believe.
#70
#71
JJH (09-04-2013)
#74
No, i decked the block .006 and CR will be between 11.4:1 and 11.7:1 depending on the head gasket i use.
NA
KN_TL (09-05-2013)
#75
The connecting rod large end bore is different between the 3.7 and the 3.2-3.5 (60mm vs 58) That is the only reason when using the 3.7 crank you have to use the 3.7 rods. Pistons are all interchangeable (in the 89mm bore engine)
#76
J30 = 162mm
J32 = 161.8mm
J35 = 158.5mm
J37 = 155.5mm
JJH (09-05-2013)
#79
It's too bad they didn't use the piston pin height to make up the difference and not the rods. So ideally J30 rods with custom pistons would be the best choice if they were as strong as the J37 which I assume they aren't.
I just don't know what Honda is doing. Usually you want a better rod to stroke ratio and especially for high revving engines you want an oversquare, not an undersquare engine. The only thing I can think of is emissions. Less top ring area to trap unburned or partially burned hydrocarbons. They obviously recognized the piston speed was getting up there with the long stroke, judging by the fairly beefy rods.
Does anyone know where you can get some inside info on the J series, I want to know the reasoning behind the undersquare design and short rod/long stroke.
