j pipe????
Old Nov 5, 2008 | 04:05 PM
tl2slow's Avatar
Bored at work
j pipe????
where can i get either the richie j-pipe or the atlp..... which one is better??????
Old Nov 5, 2008 | 05:50 PM
Sonnick's Avatar
All motor
Sigh..search is your friend. There are about 50 threads on J-pipes. Richie's username is Richie V6 you can contact him either here or over at . I'm not the username of the ATLP creator, (sorry!). So far those are the 2 that come to mind, however Excelerate is also working on one to be done within 1-2 months. Hope that helped. Search next time
Old Nov 5, 2008 | 06:39 PM
pffpffpass's Avatar
Sandy Eggo
Richie V6 Pipe..
http://www.rv6-performance.com/
ATLP Pipe..
http://acuratlparts.com/products/2/
They both look very similar in design, although are miniscule differences.
Pick one
/thread
Old Nov 5, 2008 | 08:39 PM
anx1300c's Avatar
I think the differences are huge. Equal length runners with a smooth 2 into 1 transition will make more power.
Old Nov 6, 2008 | 07:53 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
^ shoot me, everyone says "equal length"... have you measured? cuz i have
Old Nov 6, 2008 | 01:10 PM
04accordcpe's Avatar
347hp/300tq @ 4psi
even though they might not be exactly "equeal length" its not vital. it only makes a difference in the sound. the most important thing it the y pipe collector. i think thats the key advantage to mikes jpipe.
Old Nov 6, 2008 | 01:37 PM
Bearcat94's Avatar
AZ Community Team
Although the Polished look on the RV6 is pretty damn nice.
Old Nov 6, 2008 | 02:05 PM
ABP_04TL's Avatar
6-SPEED LOVER
Mikeys ATLP jpipe is hottt and so its RV6 i went with RV6 2 b different here r both of them
RV6
ATLP
Old Nov 6, 2008 | 02:30 PM
AndrewA's Avatar
Equal length is important. Exhaust gases don't flow continuously, they flow in pulses from a given cylinder with a new pulse coming with each exhaust valve opening. Each pulse creates a point of high pressure traveling through a bank tube. Between each pulse the pressure is relatively low.
Equal tube length keeps the exhaust pulses from different cylinders from colliding in the collector. If the tubes are not equal length, the pulses can collide in the collector and increase back pressure.
Old Nov 6, 2008 | 04:02 PM
Bearcat94's Avatar
AZ Community Team
Just a note on the ATLP pipe pictured above: that is painted after arrival. Mike's ATLP pipe comes in unpolished 439 Staniless Steel.
Here's a pic as manufactured (bottom, top is stock pipe):
Old Nov 6, 2008 | 10:59 PM
347hp/300tq @ 4psi
i would agree if you were talking about headers. when it comes to a header, the trick is to have all the primaries the same size so all the individual exhaust pulses make it into the collector at the same amount of time. equal length is vital and you could always tell a good design to a bad one from the length of the primaries. since we dont have headers and the manifold is casted into the head, it doesnt matter. the pulses collide in a collector, which is at the top of the primary cats. so when the exhaust hits the jpipe, 3 pulses are mixed in together.
ive had several jpipe designs and this pipe gave me the same exact results as mikes, with the exception of the exhaust note. i didnt like it AT ALL.
^^ as you can see, its pretty much the same design, with the exception of the equal length primaries.
Old Nov 7, 2008 | 11:47 AM
94 DC4 RS LSV/Turbo
atlp rear is 19" the front is 25"
rv6-performance rear is 15.5" front is 16"
Old Nov 7, 2008 | 11:09 PM
TLType-s12's Avatar
TL-S izdashiznittt in
Im not too sure about this ( dont recall the dynos) but I believe the ATLP Jpipe show more gains. (wink wink........and im not saying that because I have one)
Sombody made a comment that Richies Jpipe comes polished? Honestly guys who cares? its going to a place where nobody will ever see it!? Id rather pay a lil extra to get that lil extra.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
johnpancakes014
Sep 27, 2015 12:58 PM
Rcelestino93
Sep 23, 2015 10:01 PM
