Introducing RV6 V3 Precat Deletes Taking Deposits
#161
BANNED
Yeah I don't mind the smell but passengers do lol
What type of exhaust do u have?
If you have stock you won't notice any change in rasp just a little louder...I have a comptech so I don't have to worry about that...I'm actually looking forward to being louder and maybe a little raspier...comptech is wayyyyy too quiet ...I used to have an xlr8 exhaust and got rid of it so I could get Richies pcds lol
i've got xlr8's non-res quad exhaust n v3 jpipe. sounds great as is.
however, i plan on selling the xlr8 and getting richies new exhaust down the line.
my last car was fully catless on a set of 630cc seimens, and then a set of 540cc (60# and 52#) and no one ever complained of the smell. i ran no a/c, so the windows where always open/cracked and never had one complaint or even a comment. (unless starting it cold inside a garage/parking structure)
i doubt the smell would be any stronger in a TL with small bore injectors
#163
Losing 20% on a car that isn't supercharged is well worth the loss considering the more expensive HFPcds will eliminate the smell
The way I look at it is...I'm going fully bolted...adding enough hp to my pleasing and at the same time not making a semi luxury car smell from straight Pre cats. If the hfc version wasn't available than I'd def get the v3 no doubt but why not dish out the extra 200 and be contempt for good rather than having to sell ur V3 and buy HFPcds instead later on if ur already in doubt and torn between the decision
#164
[QUOTE=SharksBreath;12708436]lol passengers can deal...i hardly ride around with anyone except the girlfriend anyway.
right on...i never use ac either, always have the windows cracked. thanks for sharing your experience, veggie. [/]
Yeah I plan on getting Richies exhaust for the 2nd batch because I am going to do a type s conversion
#165
I am also interested in the high-flow pre-cats. I really don't want to hear a raspy sound when I'm riding in a luxury car. Looking forward to seeing a dyno chart.
Couple questions about the hfpcs:
1. Will the car still pass an emissions test? Will it pass emissions if I am running the j-pipe in addition?
2. About how much should I expect to pay for install?
#168
Former Sponsor
BANNED
#173
'06 WDP TL 6MT
While everyone waits, a question! The stock precats have studs at the bottom where they are attached to the j-pipe. It looks like these PCD's are attached to the j-pipe with nuts and bolts?
#174
Former Sponsor
I checked yesterday they are starting to tap all the holes. I could get them to do 25 sets first. They had to machine one type of casting at a time. There are over 800 castings.
#176
Former Sponsor
BANNED
good to hear!
can we make the final deposit on your website yet?
thx for the update richie.
#182
Former Sponsor
Will be adding final payment option to the site soon. I will be spending the night cutting tube so my welder can get started ASAP. I am also sending the first set to be ceramic coated this week. After the first set I will have a final price on the ceramic coating. Thanks for your patiences.
#183
BANNED
sick.
can't wait to install these, looking forward to the next update!
#185
BANNED
^if installed correctly, no CEL will pop up.
might want to check your local emission laws tho...some states do visual inspections and more. my state just hooks you up to a scanner and if nothing pops up they set you free.
#186
2005 AM at/navi
what a great update richie. now i just have to decide on hfc or v3 pcd. will these provide the same torque gains? im more interested in torque than peak hp
#190
2005 AM at/navi
#191
takin care of Business in
Received 4,732 Likes
#192
2005 AM at/navi
every TWO years swoosh. i still thinks its all good in order to have more fun with the car... lol
i already have the rv6 v3 j-pipe and my tsudo cat-back so i wont pass anyways. im not too worried about that.
i just want the most torque but not too much rasp so im still debating on which one to get... v3 pcd or hfc???????
#193
All motor
Search the forum. There are a few dyno threads with numbers before/after PCDs. No one has these yet, but they should put out equal if not slightly more gains than the previous PCDs. The HFCs should be within 3-4hp of the PCDs.
Also, everyone's setup will be different. Every catback is different. Each catback will react differently to each Jpipe. And in turn, will act differently with the PCDs as well. Just because someone else gained 15whp doesn't mean you will. You may gain 13, you may gain 17. They help a lot with top end power. If you have a 6MT, you're looking at 10+whp gains easy.
#194
yup 2 years in some states and 1 year in some states....but yeah....if you have a hookup...thats the shiznitz....
#195
2005 AM at/navi
yup im glad this can be done. only other risk is that chp is well trained out here on modded exhaust...
#196
Former Sponsor
The new tube we are using is so thick it leaves a lip inside of the castings. In order to get a smooth transition I sent all the tubing to a machine shop to have them put a 45 degree chamfer on the ends of the tube. This makes for a perfect transition from tube to castings. My welder is welding the first 30 sets this weekend. Hopefully I can ship some out early next week.
When I pick up first 30 sets of PCDs ill drop off the cores for the HFPCs.
#198
BANNED
#199
#200
