Introducing RV6 V3 Precat Deletes Taking Deposits
#41
Former Sponsor
Stock precats 16lb 15oz
V3 PCDs 8lb 11oz
Weight reduction over stock
8lb 4oz
V2 PCDs 5lb 6oz
Weight increase from V2 PCDs
3lb 5oz
I will do it. Did are you still CEL free with 8th gen?
V3 PCDs 8lb 11oz
V2 PCDs 5lb 6oz
How much theoretical HP is that?
I had them offset the casting slightly and eliminate the notch there should be no issue running the heat shield. No more phone calls from angry customers wondering why their pipe is dented.
They basically remove the cats, so it increases the emissions. They are definitely not smog legal.
#42
2005 AM at/navi
how long will you keep the $345 price on these richie? i want to see the power the hfc option gives us compared to the pcd. i am only concered about the rasp because i just recieved ur j-pipe so if i can reduce the rasp without sacrificing TOO much power i may be interested in the hfc option, but if it does sacrifice power too much i will suck it up and go for the pcd but i dont want to miss out on the $345 price.
#43
V3 PCDs 8lb 11oz = 8.25 lbs less than oem = 0.508 HP Increase
V2 PCDs 5lb 6oz = 11.56 lbs less than oem = 0.713 HP Increase
Going from a V2 to a V3, you will loss 0.205 HP based on the weight penalty.
Relax folks, this is just a joke between me and Richie. But, it is true.
Another feature of the thick-walled casting is that a person can easily drill and tap it to install a EGT gauge. For mine with the V2, I had to get it welded.
#45
All motor
With that "dent" removed, they should definitely flow better....hmm.............................
#46
Former Sponsor
#48
2005 AM at/navi
#53
so Richie quick question with this V3 PCD. Since these are out does that mean my V2 pcd will crack or you just made these just to beef it up even more. Don't want to update if there is no power difference and the V2 are working just fine for me........
Either way though great product update those V3 look good!! As always amazing stuff Richie
#54
All motor
I have a ? too Richie. What are those acronyms in your first post? CAD? And the other one? How do those 2 make these V3 flow better than the V2?
#55
Former Sponsor
I will try and get some details up this week. I have been swamped getting this exhaust out.
I had these made since they are stronger and easier to manufacture. There is just 4 welds now instead of 6+ and no more weird bends.
CMM Coordinate-measuring machine The stock precats were scanned for exact measurements. The transition from flange to pipe is much smoother now, almost like a funnel. Before we had to abruptly stretch the tube in order to fit the head flange.
#59
#62
Former Sponsor
My prototype set is a little dirty and dinged up.
Sneak peek.
Sounds fine with me I will PM you.
Sneak peek.
#63
2005 AM at/navi
i guess thats the hfc v3. they look sick. any info on price and power gain difference compared to the pcd v3? this will help me make up my mind on which to order. great work man
#66
Former Sponsor
Lost wax casting, the surface is quite smooth.
The piping was delivered this week, 20' sections are a pain to handle. Stainless 304 in 14 gauge. Exhaust are typically made with 18 or 16 gauge. (smaller gauge = bigger)
#70
Former Sponsor
I will look into it I am guessing it will be 100-150 extra for a polished ceramic coat
#71
I don't own any RV6 products yet, but am waiting patiently to purchase the HFC's and at this time I would like to nominate Richie as the most innovative R&D guy/vendor of TL performance products for 2010. Hell, make that every year.
#72
BANNED
richie, how's the progress on these coming along? eta date still end of january?
#77
wow...look at those! look beefy. i can attest to the durability of the V2's. The V1's were great, but with the amount of abuse i took them through, it's no wonder why they cracked (albeit, only the rears). The V2 replacements that Richie sent me went through the exact same (well, maybe a little worse) abuse + frequent hard launches (60A Innovative Motor Mounts <- didn't take the abuse by the way, as they FLEXED and were replaced) and survived without any sort of breakage. PHENOMENAL PRODUCT and EVEN BETTER (PROBABLY SOME OF THE BEST) CUSTOMER SERVICE, I'VE EVER, EVER, EVER HAD THE PLEASURE OF EXPERIENCING, in my LIFE.
Hope all's well RICHIE! Thanks again man!!!
#79
Former Sponsor
I am going to try and find a local TL to dyno for me. My trans is out in my TL, I am waiting on a few companies to get back to me on upgraded clutch packs on the autos.
