Intake Silencer removal
Does anyone have pictures of this mod or the missing picture from this thread?
https://acurazine.com/forums/showthr...ntake+silencer
i was wondering about this to. i want to do it but the pictures on the DIY dont work. anyone have pics?
What are there noticeable gains when velocity stack is added? What about the Ait filter, if its removed what do we do with dust and debri going into the engine. Please school me on that if you know
I'm not sure which brand they are using, but here is BPI's info
http://www.bpinitiatives.com/kits.php
results after installing BPI, yes the car is modded.
http://www.honda-tech.com/showthread.php?t=2231492
More results.
http://forums.aspeedracing.com/showthread.php?t=6652
I know I'll get flack for this but... When removing the resonator how does the sound compare to a SRI? I have an auto tls so I'm realistic with the car's potential and would like to at least make the car a bit more fun to drive (intake sound).
So in short- is there a noticeable sound difference between removing the stock resonator VS installing a SRI? Which sounds more aggressive? I'm sure the SRI would, but i figured I'd ask. I'm still a relatively new Acura owner.
Thank you in advance for the info!
Just took mine out today, took me only about an hour (including 20 min joy ride). It sounds a lot better, its not CAI but you can tell the difference. Also I think that the throttle response is a little better
I did. It might be a lot more difficult without bumper removal because you do have to yank it kind of hard to get it out.
The bumper removal takes like 10 min if even that
under renovations....
Don't you mean more like a "warm" air intake. The pipe that returns back up sits right between the headlight and battery. And there is an additional cover that kinda hides the end of the piping which is removable. I looked at that a thousand times and to me it just doesn't seem like it's pulling in cold air hence why I said warm air. I think if you were to just end it with a velocity stack right down by the foglight area you'd get a better cold air charge.
