Installed Hyper Hot InaZma Voltage System. Wow.
#41
Wow was is this?- http://www.eautoworks.com/product-To...0/Acura-TL.htm
#42
It isn't. It is a reply like many of the others above. Maybe a little sarcastic but not really worthy of a BPR.
#43
How about instead of getting fucked by the green dick. You guys just invest 45 dollars into some stereo wire and components and make the same thing.
Actually screw that. I am going to make my own, sell them on ebay for 150 dollars each, to undermine the competition, and install free kits on my friends cars and have them rave about it on car forums, and split profits with them.
... this is really a joke right. I do believe that it "helps" the car electrically, but it is NO WAY generates more HP. Freeing it up in some way maybe. Its like adding a flywheel to a transmission. You didn't get HP, you just decreased rotational mass. Its like robbing peter to pay Paul.
#44
.43g at 900+fps
like i said before, stereo amp wires work just fine. kits just look cooler and got a brand name. thats all you pay for. i use amp wire. then i could custom tailor the lengths so it wouldn't look like colorful spaghetti with too much slack. doesn't add power. in fact, no bolt on ADDS power. just unlocks what was already there. forced induction, nitrous, etc ADDS power. but we already knew that.
#45
Electricity requires a good ground- the better the ground- the better the flow of juice-
Hi performance hi demand ignitions like the TLs require it- keep the battery cable connections clean and where the ground wire goes to the body- remove that and sandpaper everything so its bare metal to metal!
Adding any solidly built ground wire system is going to help stock cars, and really help modded cars.
Find a place on the fender well- drill some holes in a metal plate- yadyada you got the trick setup
Its off to the scavenge parts pile in the garage and make one for me now!!
rockyboy
12-06-2022 02:29 PM
cycdaniel
12-17-2019 10:58 AM
