Installed Comptech SS today
Old Oct 28, 2007 | 09:45 PM
sho_nuff1997's Avatar
I disagree with unanimity
The throws are awesome now. I can't believe the difference that little piece made. It feels a lot tighter going into gear. I'm not sure if it is supposed to be like that, but I like it. I took less than 2 hours with the help of jmbnova's excellent write up. It was well worth the $60 spent for the SS. I recommend it to all 6MT drivers!
thanks for your write up jmbnova!
Old Oct 28, 2007 | 09:51 PM
INSANETL's Avatar
INSANETL
60 for the SS?
how much installation?
Old Oct 31, 2007 | 08:35 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
yeah i LOVE mine and i did it in an hour or so. if i drive a stock TL it feels like shit
Old Oct 31, 2007 | 09:51 PM
csmeance's Avatar
if you want better shifts, look into adding bushings to the cables from the RSX i believe, a search for shifter brushings/bushings will give you the proper threads.
Old Oct 31, 2007 | 10:10 PM
eh? spec's Avatar
Cruising in my
It only took an hour to install?
From a previous write up I read from a while back it looked pretty tough to do... so I never bothered. I'd like to but for some reason I'm scarred to take the console apart...
Old Oct 31, 2007 | 10:44 PM
type-s09's Avatar
13.2@ 107 on Street tires
its just some bolts and screws...if you dont have patience dont do it cuz you will be replacing some interior pieces
Old Nov 2, 2007 | 11:40 PM
zoostation's Avatar
Besides the shorter spacing between gears...how is it different?
Old Nov 3, 2007 | 09:56 AM
Kennedy's Avatar
OMGWTF4THGENTL
The SS doesn't shorten the spacing between gears.
It "lengthens" the throw arm, which means it takes less movement of the shifter to move the shift mechanism.
With a shorter throw means "more tightness" because it takes more effort. It's like a lever (the simplest machine). If you make the lever arm shorter, it takes more effort to raise the rock, but the less travel.
For those with the SS... There are 3 complements you MUST install with it:
- Skunk2 weighted shift knob. This helps with the effort a bit.
- Aluminum shifter bushings, these take the slop out of hard shifting.
- GM Synchromesh or Specialty Formulations MTL-P fluid.
My shifts are like those of an indy car now.
Old Nov 4, 2007 | 07:22 AM
zoostation's Avatar
Excellent explanation. Thanks
Old Nov 6, 2007 | 02:17 PM
chongbo's Avatar
so where do I get all these parts
sounds awsome so where can I pick up some of these parts and kit for my 2007 TL-TYPE-S 6MT?
Who sells this is what I am asking
Old Nov 6, 2007 | 03:38 PM
aznbo187's Avatar
The GM Synchromesh you can get at your local GM dealers part department, or you can get Pennzoil Synchromesh from pepboys, their both the same thing and GM makes the synchromesh for Pennzoil.
Feb 25, 2020 09:57 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
k6biv
Sep 22, 2015 02:06 PM
k6biv
Sep 10, 2015 06:37 PM
