Insane raspiness...please help!
Old Jun 6, 2013 | 06:10 PM
bugs2k's Avatar
So I have an 07 tl-s automatic and I just finished with my PCD's install, and Holly crap the rasp above 5k rpms.
I have a unresonated xclr8 quad catback and rv6 v3 j-pipe.
I don't want to get rid of the PCD's because the power gaines are so noticible.
Should i install a resonator in the exhaust, would this help?
If so which kind or brand?
Old Jun 6, 2013 | 06:27 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Vibrant resonators do good for how small you can get them.
Old Jun 6, 2013 | 06:29 PM
install a resonator to fix the rasp
magnaflow 10436
P.S. there are tons of threads on this.
P.S.S most resonators get rid of rasp.
pick one either the vibrant or magnaflow and install it.
Old Jun 6, 2013 | 06:57 PM
bugs2k's Avatar
magnaflow 10436
Yeah i did some more seaching and found the main thread from Richie.
So the 10436 would work best? Ok sounds good.
Old Jun 7, 2013 | 02:06 AM
sockr1's Avatar
check out this thread someone recently posted about rasp and drone. they went with magnaflow 12640 which is bigger but not necessarily the best choice if you are slammed. i currently have the 10436 even though i only have HFPCs and it definitely helped
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/atlp-resonated-quads-still-have-drone-887942/
Old Jun 7, 2013 | 07:39 AM
zachlone's Avatar
PCD and jpipe, what did u expect? you are running no cats now so of course you will get rasp! resonator should help
Old Jun 7, 2013 | 08:07 AM
350's Avatar
350
My first ricer
Run the biggest resonator you can fit, it won't affect flow or cut much volume.
Old Jun 7, 2013 | 08:17 AM
bugs2k's Avatar
Local muffler shop has 18" dynomax 4" round resonator with 2.5" outlets. This should be about same specs as the 10436 magnaflow. Dropping off monday morning.
Old Jun 7, 2013 | 08:53 AM
Sonnick's Avatar
All motor
Be aware that both Dynomax mufflers I've used resulted in a tinny, metallic noise at certain RPMs. I wouldn't buy from them again.
Old Jun 7, 2013 | 09:31 AM
bugs2k's Avatar
Thanks I will see if he can get the magnaflow or equivalent.
Old Jun 7, 2013 | 09:51 AM
sockr1's Avatar
i would go with something larger, you will still have rasp with that size. the 10436 is 22" by 4", the one you are gettting is like the 10426.
the 12640 is a 6" one and much bigger. i would re-consider getting the dynomax one, magnaflow is way better and you will need to at least get 4" by 22"
Old Jun 7, 2013 | 10:00 AM
pohljm's Avatar
I agree, as large as you can fit to reduce the rasp!
Old Jun 7, 2013 | 02:39 PM
bugs2k's Avatar
He is ordering a few different ones and they will be in monday. I will get the largest one i can fit under the car.
wreak
Oct 1, 2015 10:56 AM
suka4thong
Jun 4, 2004 08:32 AM
CraZee ZO6
Apr 14, 2004 02:00 PM
