I got re-dynoed
300whp 237wtrq
I got re-dynoed
So, I decided to get re-dynoed since I changed out the intake from the comptech one to a homemade CAI and also the Crank pulley.
I did these runs WITHOUT methanol because i have a leak on one of the hoses, I ordered a new hose so that should take care of it.
My previous dyno was back in 2006 with:
CT S/C
CT intake
CT exhaust
Eshift Pro-Cats
and I got 289.3 whp and 237.1 wtrq
This time I had:
CT S/C
Custom intake
CT exhaust
Hyper Voltage and ground
Eshift Pro-Cats
UR Crank Pulley
and I got 300.2 whp and 237.1 wtrq on a 2005 5AT TL
This SAE corrected and on a DynoJet...funny how I got the same amount of trq
CT S/C
CT intake
CT exhaust
Eshift Pro-Cats
This time I had:
CT S/C
Custom intake
CT exhaust
Eshift Pro-Cats
UR Crank Pulley
300whp 237wtrq
Originally Posted by anx1300c
Damn, that's sick; 300 whp in a TL. I can only imagine that set up on a 6mt car. Have you tried running the quarter with some drag radials?
Originally Posted by Schulminator
Wow, imagine what a proper TUNE would do????
I would be very interested to see a run on methanol. Should make a huge difference.
300whp 237wtrq
Yea, I was hoping too, but when I got to the dyno place, I noticed my methanol tank was almost low and I had filled it up right before I left. then we got it on the dyno and we noticed Methanol everywhere... damn leak
Oh well, I ordered new hoses and connectors. Snow performance said they recommends replacing those once every year or year and a half.
300whp 237wtrq
Look how much power I lost in the low end (top end was the same) on back to back run from heat soak.
The red line is the same red line that is show up top. The blue line this time was my first pull today. The blue line on the first pic was from 2006.
300whp 237wtrq
Originally Posted by dr_brains510
so you got a 10 whp gain from the UR Crank Pulley? btw, what is hyper voltage and ground?
The Sun Hyper Voltage System is this... mines black though
"The H.V.S. is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released."
When I installed it i felt better throttle response, car started faster, and a little more oomph on the butt dyno.
300whp 237wtrq
Originally Posted by ussi
MugenR, where did you install the methanol nozzle?
Also, did you install the HVS kit before or after you put on your supercharger?
the Methanol nozzle was installed after the blower on the supercharger elbow that connects to the intake manifold.
It's been awhile, but according to my Modification Log sheet I keep, yes... I'm a dork. the HVS kit was installed after the supercharger.
94 DC4 RS LSV/Turbo
Hah, dude I drove actros wdp insanity, when he said I could drive I was jaw dropped, and in all actuality it pulled hard forward not that much side to side torque steer (I guess its cuz there wasn't much torque added as opposed to the type s), but it sure is fun going 40 to 60 in half a second, not to mention how addictive the whine is
300whp 237wtrq
Originally Posted by kosstick
sooo a Ur crank pully gave you how much ?
Originally Posted by BLACKURA_NY
id love to drive a supercharged TL just once, to see the crazy amounts of torque steer... from my 227whp TL, to my 261whp TL-S, the difference in torque steer is EXTREMELY noticeable
Originally Posted by 04accordcpe
nice #'s! imagine how your car will feel with a good tune of the a/f
That shop doesn't like tuning Greddy Emanage though, They've had problems with it and don't like to hassle with the jumpers.
I'm tempted to drive down to cali this summer for a church tune
347hp/300tq @ 4psi
Originally Posted by MugenR
Yea. the guys at the dyno were shocked that I was running at 10 A/F.. lol... They were tuning an accord 4cyl with turbo right before my dyno run and it was running pig rich too and it got around 250 whp, but after tuning the A/F, it got up to 300.
you will find ALOT of dyno shops wont deal with the emanage. ive had one dyno shop tell me they will do it, only if i bring my own laptop.
DER NEUE ^
The magic is in the suspension bro...
DER NEUE ^
Hbp and custom j(a) pipe helped the engine produce 100hp per liter to the wheels, for the most part! Before the higher boost pulley the car was consistently at about 300 and 250 respectively.
I wish I could post those dyno sheets for comparison but Mike never gave me them, something was wrong with a printer or whatever, oh well.
tehLEGOman
Received 1,983 Likes
Good numbers Andrew!
..i'm glad to see you back into the mod bug after being dormant for quite some time!
94 DC4 RS LSV/Turbo
Originally Posted by ACTROS
Actually, that car was rated at 320hp/270tq
I bet, the h&r coilovers felt perfect, almost couldn't tell it was even a coilover setup
Really liked how it just pulled forward with such smoothness, guess the chilled evening when I drove it helped
Real curious to see what your next car will be
TL-S BeASt
guys please answer this......is there going to be a supercharger for the TL-S, i get the feeling that it may not ever exist! I'm hoping that they make one soon! Any thoughts or hear say?
300whp 237wtrq
So I changed out my crappy build of an intake and changed it out to something MUCH MUCH better. Before in second gear, I'd never be able to read more than 3psi of boost. Now it's reading a constant 3.5psi and spikes up to 4-4.5psi
I also go the methanol fixed. changed out all hoses and plugs.
Here is a pic of my old intake setup, I'll get another picture up on my new intake setup tonight.
That accordion looking tube was creating so much turbulence. I did a quick test with compressed air, sent it through my old intake with the accordion tube and then through my new intake... the old intake you can tell the exiting air not as cold as the new one and also the air is not as strong.
300whp 237wtrq
Here is the NEW and improved custom intake for my Supercharger. 04accordcpe's design was my inspiration
And here is the entire engine bay.
300whp 237wtrq
Originally Posted by bent09
Looks nice. I take it you just cut an aem then bought the hose.
Where did you get the hose?
I got a cheap little 98-02 4cyl accord ebay intake. this intake had all the right bends i needed (I still had to cut it up). and I got the blue silicone hose on ebay as well. search for "3" inch Silicone Hose Coupler 90 Degree Elbow"
300whp 237wtrq
reeeee- dyno! lol
i hope your on the ATLP j-pipe buy list. that will definitely get your #'s moving into like 320+
Unfortunately I got hit with some unexpected bills this month, so the J-pipe will have to wait till the second batch I hope to god there is a second batch.
