High flow precat gains?
Hey guys,
I just did a mid muffler delete today on my TL. I'm going to be getting a j-pipe next and then probably high flow cats. Does anyone know what the gains are on high flow pre-cats and the cat after the j-pipe? I spoke to the guy at the shop who did my muffler mod and he said I wouldn't gain much from high flow cats. I can't use the PCD's since it would fail emissions. I live in Allegheny county near pittsburgh. I'm wondering if PCD's would pass emissions too since they would be barely visible anyway. |
^you dont say what model your car is.
base cats have a cell count of 900. type-s cats have a cell count of 600. High flow cats have a cell count of 200-300 pcds are straight pipe so it has 0 cells. from the base TL to high flow cats you'll be going from a 900 cell cat to a 300 cell. pretty big improvement. |
(Post 13917951)
base cats have a cell count of 900. type-s cats have a cell count of 600. High flow cats have a cell count of 200-300 pcds are straight pipe so it has 0 cells. from the base TL to high flow cats you'll be going from a 900 cell cat to a 300 cell. pretty big improvement. Sounds like that would be a huge difference. I will definitely be getting them then. |
(Post 13917951)
Originally Posted by Bruce Banner
(Post 13918093)
So for his 08, is he looking at like 25HP gain?
(Post 13918093)
(Post 13918093)
^^^ well if that's about 12 hp per HFC, then there's your 25 whp! lol
I meant all toghether....
I know...I guess I should've used red letters......thought the "lol" was good enough...
(Post 13918115)
How did you come up with this number?
:werd:
(Post 13917951)
pcds are straight pipe so it has 0 cells. Would that be a 1 cell instead of a 0 cell? Not to nitpick or anything :tongue: |
(Post 13917951)
theres only a 3hp difference.....usually emissions is always a factor...depends on where u live I guess....^^^^^^I love my HF's
Originally Posted by Italiano
(Post 13918733)
I like the slight growl it gives at idle. I never experience the HFPC without the V2 at WOT, so I couldn't tell you about that. But I notice it on teh butt dyno,
Somebody get some dyno data into this thread
+1 for loving high flow cats
+2 here!
What kind of effects would a PCD have on the Type-S engine??
(Post 13919200)
(Post 13917951)
Originally Posted by Sterling McDaniel
(Post 13919328)
hfpc or not get ready for your exhaust to have some rasp
http://farm7.staticflickr.com/6139/5...986446c5_b.jpg
Justin 6MT - Rv6 V3 PCDs, RV6 v3 jpipe Emmanuel 6MT - stock |
Originally Posted by KidChenz89
(Post 13919714)
Would just pcd's on my type s yield exhaust rasp?
Originally Posted by JJH
(Post 13919492)
From what I can deduct from Justin's post, a base TL will yield the biggest improvement while PCDs for a type-s will only be a small improvement considering the type-S already has higher flowing cats than the base. Although, the Honda manufacturers decided to add to production costs by making two different sets of cats for the base and type-s and there really isn't that great of a difference in cell count so maybe a little bit does help? You would be going from 600 cells to 1 cell. :tomato:
(Post 13919714)
I read a tech article a while back that said when the type s came out 6hp was gained from going to 600 cell cats from 900 on the base. This makes sense because the 4g TL has the same engine as the type s but is rated at 280 since it has 900 cell cats vs 286 in the type s with 600 cell cats. Using that logic, I bet you would get 6hp for every 300 cell you lost on your primary cats. If I come across that article again, I will post the link.
My best guess is that on a base TL you will get: 6hp going to type s cats 12hp going to HFC 18hp going to PCD Shameless plug: If you want the most gains possible, buy my V3 RV6 PCD for sale in the Black Market :thumbsup: |
Originally Posted by anx1300c
(Post 13920190)
A Type-S will still gain heavily from the full deletes. Going from 600 cell cats to straight pipes is still a vast improvement. In theory, it's the same flow improvement as going from the stock 900 cell base cats to the 200-300 cell HFC's.
High flow cats do not, in and of themselves. add rasp. I have none. |
Originally Posted by Andy Tsang
(Post 13920199)
Thanks for chiming in wanted someone with experience to give their two cents.
Nice thing about the HFC's is you don't have to worry about hacking into your exhaust and adding a huge resonator if the rasp gets annoying. My Excelerate cat back is the resonated version, but the resonator is so tiny I don't think it's doing much. |
^just wanted to emphasize on the Variables part.
my set up does rasp, but I dont have any plans to quell the sound. Unless, I were to get the rv6 exhaust. also, our vee six is designed to sound ugly. lol its just the way our motor sings! |
Just an FYI, back when I had pre-cat deletes, and test pipe. My bumper turned yellow-blackish if I didnt stay on top of my weekly washes. Keep in mind I also have a white care. Im sure it doesn't show up on darker colors.
Originally Posted by lilsid112
(Post 13920916)
With windows down at a stop, could you distinctly smell the emissions? |
(Post 13920962)
(Post 13920916)
Taming the beast! PCD Rasp (videos posted) (click here) http://pic80.picturetrail.com/VOL836.../391172795.jpg http://pic80.picturetrail.com/VOL836.../391172793.jpg |
(Post 13920962)
Originally Posted by Inaccurate
(Post 13921036)
(Post 13919967)
(Post 13918204)
No way in hell....its more like 12hp:thumbsup:
Originally Posted by 3gstealth
(Post 13920197)
(Post 13921036)
It happens to dark colors too.
I usually take care of the copper color during a wash.
the bumper will need to be rubbed with rubbing alcohol and the tips can be taken care of with bar keepers friend |
| All times are GMT -5. The time now is 10:04 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
