Help w/ Big Brake Kit?!
Long story short, I've decided to scratch the blower and in its place, purchase a big brake kit! I've done a few forum searches, but I didn't quite find what I was looking for: so the question comes to YOU experts! So...being inexperienced with ANY sort of brake upgrades...I don't quite understand the difference between the brands, nor do I understand the purpose of slotted/drilled calipers. I'm only looking for a big brake kit so that I can stop faster; I've been in some situations where I HAVEN'T BEEN ABLE TO STOP-biggest scare was on the freeway going 70 when some truck decided to dump its cargo right in front of me...and two other cars! I'm a STUDENT working his way through, so I don't exactly have a very large "disposable" income...but I'd rather pay the price for the RIGHT SET versus the cheap knock-offs; trust me, I've had my fair share...I've learned that if I'm going to do it, then might as well DO IT THE RIGHT WAY. SSSSOOOO...Brembos, Stop-Tech, Rotora?! Which one!??!!?
Oh and how much can I expect to be throwing out?...atleast 2k? under? OVER?!
Thanks all,
Eric Kim
...I REALLY, really appreciate all your input!!! Thanks much!!!
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
Thanks all,
Eric Kim
auto trans - ok you can get way better rotors and pads- possibly 2 piston calipers in front, and keep a reasonable budget.
I am checking to see if a gen2 mod of calipers will fit gen3- no word yet.
RacingBrake and Rotora and EBC all have excellent rotors and pads
The side slots are a nice upgrade if you drive hard- they allow an escape path for the gasses the pads expel during hard use-if you race-,those gas pressures can be high and need an outlet
If you street drive like a normal human there is no real need for cross driled, or even side vanes.
Basic flat rotors made of good metal with quality pads-- design performance matched, are good for you.
See vendors Excelerate and MrHeelToe for those items- check off topic link- then Sponsored Sales area for their post
you can get a real 4 piston or 6 piston caliper setup- about 2-2500 as you suspected, and it will need bigger rims to clear the bigger calipers and rotors (1 inch largr diameter)
Check the sig with mods of members, every brake combo possible is being used!!
'10 Hyundai Genesis Coupe
You could also do what other members have done which is a 6M/T brake coversion into the 5A/T it was around 1.2K, but its a good increase in brake performance.
AZ Community Team
Received 7,771 Likes
Lots of choices to improve the capability.
- Rotora or StopTech BBK (assuming they'll fit an Auto)
- Racing Brake 2-Peice Front Slotted with StopTech Slotted Rear (again, assuming they're available for the Auto)
- Racing Brake 1-Peice Front slotted, StopTech Rear Slotted (assuming ....)
- Rotora Slotted or Slotted & Drilled replacement rotors
I am sure there are more. Good Street Perfomance pads to go with 'em.
Slotted - generally thought to be the best performance with good cooling/stopping character.
Drilled - mostly for show. Some increased cooling and/or weight reduction. Loss of surface area may reduce stopping performance. Some have a tendency to crack.
Slotted & Drilled. - Again, generally, the slots are for performance, the drilling is for bling. I assume if they are high quality (i.e. unlikely to crack) and larger than stock, they'd provide the most cooling, least mass per unit area and a good increase in stopping performance from stock.
On my '02 TL-S, I went with RB 1-Peice slotted front, StopTech Slotted OE Replacement rear and ET500 pads. So far .... F'n Awesome.
Former Sponsor
Build your own brake kit here!:
http://www.heeltoeauto.com/Heeltoe-B...-pr-40006.html
Marcus
AZ Community Team
Originally Posted by MrHeeltoe
Racingbrake has slotted rears for the 3G TL, just no the 2G.
Marcus
Marcus
Excellent! Thanks for clarifying. So far, I am very happy with the quality of the RB rotors. Wish I'd would've had the scratch for the 2-peice.
Originally Posted by erick3
well...now that I look at the thread...the Rotoras are actually cheaper?! oh boy...
No, the quote for the M/T brake conversion was 1600$, but also included installation from the DEALER.
The problem with the Rotora and other BBK is that they won't fit the stock TL wheels, which means, if you want those, not only do they cost $1400 without installation or brake pads, but you'll need a larger wheel in order for them to fit.
Also with the M/T brake conversion you're not simply upgrading your rotors, you're getting an upgraded and better looking front caliper which is a 2piston setup.
I plan on going this route as well, but if the Rotora BBK fits a 17" stock wheel, then I would go with those because they look so cool!
Acura TL V6 A/T (04+)
- ROTORA 1 Piece Front 330MM Disc w/ 4 Piston Caliper BBK - $1300 shipped
- ROTORA 2 Piece Front 330MM Disc w/ 4 Piston Caliper BBK - $1725 shipped
- ROTORA 2 Piece Rear 330MM Disc w/ 2 Piston Caliper BBK - $1475 shipped
Those are the prices for the Rotora BBKs from Excellerate.
If you're going for the least expensive brake upgrade, what MrHeeltoe offered, is the best route, but those will only upgrade rotors and pads, not the calipers.
'06 750Li Sapphire/Creme
? Why isn't this in wheels, tires and suspensions? Aren't Brake threads normally over there?
Former Sponsor
For the BBK, the 2 pc disc will have its advantages. Aluminum hub with iron disc, curved vanes, less spinning weight, better cooling capacity and less chance of distortion. However, the 1 pc setup with 4 piston caliper should be sufficient. It will be a better setup the than the M/T TL Brembo setup b/c it is a 13" disc with SS brake lines and more aggressive street pads and at less of a cost.
Originally Posted by Excelerate
Actually the ROTORA 1 pc disc will clear the stock TL wheels. I'm not certain on the 2 pc disc. I know it clears the 18" Aspec wheels but not certain on the 17" wheels. It may require a 5mm spacer at most.
Well if you think the Rotora BBK will fit a stock 17" wheel I want one, because that's the only thing that's holding me back from ordering a set.
Oderint dum metuant.
^Josh wouldn't lie to you; if he says it fits, it fits. Aside from that, ACCURATEin had the kit with the stock wheels for about a week...perfect fit.
Josh - are the calipers that come with the one-piece kit different than the calipers that come with the two-piece kit? I would've thought the only difference between the kits was the rotors, but that everything else was the same.
I was considering getting a big brake kit for my TL but since the price was about $2,000 and upwards I decided on getting some slotted Rotora rotors and Hawk pads. Getting new rotors/pads will make a nice difference but it won't look as pretty as new calipers. The price diff. is quite significant so its all up to what you think you'll need.
Slotted rotors will last longer then slotted/cross-drilled rotors, and unless you'll be doing autox or tracking the car I would just go for slotted. This will help with allowing hot gases to escape, and so forth.
'07 NBP TL
i have the rotora 1 piece front 4 piston and 2 piece rear 1 piston and they both clear my stock rims. but I have a 07 base TL. I'd assume it'll clear the 04-06. Also you might need to get a different spare.
CTS-V Import Slayer
Originally Posted by chill_dog
^Mike, do your stock 17's fit over those?
Former Sponsor
Former Sponsor
If you can get your ABS to come on under braking you don't need new calipers.
Marcus
Interesting note on ABS Marcus
When I was on stock mickyslip tires and acura brakes, I could get to ABS fairly easy~
Now with the RB rotors and pads- with Legend 2 piston calipers, General Exlaim tires on 18 inch rims-,2001TL-P
Even at max sudden braking effort on normal surface roads, It just slows and stops, very quickly and predictably. No thought of ABS activating and doing the driving for me, its not needed!
Has done really well in full wet conditions too, feels like its in the dry!!
I dont care what people decide is right for them, all I know is: better brakes save lives, and keep the car OE length during those freeway stoppages that appear from nowhere~
Marcus
Marcus
I don't think I need upgraded calipers, but I love the look and personally the stock TL brakes can barely stop the TL, I have absolutely nothing in my car other than myself and on a hot day the car will get brake fade after 3 stops. They feel really gummy, not sure if you'll understand what I mean.
Also when you have 2 or more passengers you can feel the car has difficulty stopping.
Former Sponsor
The look I could agree with for sure. But pads are what are going to help the stopping with stock calipers. You can find more bit and fade resistance without plopping down the OS caliper cash. Fade has more to do with rotor and pad overheat than caliper pressure.
Marcus
get good pads and rotors- with good tires
Thats the affordable option on the TL - in my opinion
Airbags are for crashing- Brakes are for avoiding the accident altogether
Until you test ride with a ziner who has upgraded parts- you cant believe that these cars will stop on a dime and give 8 cents change~
but they really will
synthetic brake fluid going thru SS lines gives improved feel and heat resistance-fade
Two items to add -
1) Vehicle weight is a big factor with braking performance. I don't expect you to do a TL Diet, but try to keep unnecessary items out of your car/trunk.
2) ABS in our cars (as opposed to older Acuras that I previously owned) is hard to detect when it activates. In older models, the pedal would pulse violently. In our TL's, the ABS pulses with extremely small and fast pulses that could be hard to feel. I engage my ABS approx every other day (on average). I always drive barefooted (with no shoes), and I easily feel the ABS thru my bare foot. But, I could see someone missing it that was wearing heavy shoes.
Originally Posted by Inaccurate
Two items to add -
Always keep the trunk empty, sometimes I'll even kick out passengers!
nuldabz
09-03-2015 05:49 PM
