Head porting
Head porting
I'm looking for good honda head porter. I saw a guy/company in California mentioned in magazine a while back. I believe a good head port job is worth about 40 hp.
Anyone?
Anyone?
Depends on how well the stock heads flow and how much extra meat is in them. Typically you can expect 20-70hp. Freeing up the intake like extrude honing the manifold, and freeing up the exhaust is mandatory. Bigger cams also compliment ported heads nicely.
Port and Polish for heads, combustion chamber and intake manifold
Multi-angle job on the valves
Stiffer valve springs
Lightweight titanium valve retainers
custom cams
bored out throttle body
throttle body matched intake manifold
thermal gaskets
if you do any of this, make sure a reputable shop with a flowbench does it to show you numerical gains in flow.
i'm sure there will be gains from it, i just don't know how much. it would be good to match port and extrude hone the intake manifold (upper and lower), if you gots the cash money to do it. might not be worth the money though.
if you have a bit of money to spend why not do this:
custom cams
thermal gaskets
custom cams
thermal gaskets
how about just for port n polish or extrude honing?
custom cams
thermal gaskets
custom cams
thermal gaskets
I def got gains from this... NO WAY in the range of 40hp.
What I found was the heads looked pretty free flowing. I didn't do a benchflow, I just saw the before and after. I did all these mods at once and I'm SURE it free'd up some HP. But the only way you're going to realize the benefits of this is if you are supercharged AND tuned.
I've most all of this, and put oversized intake valves.
Did you check out the site I linked a few posts up?
yup. same as what I see. Think AZ is still under major construction. My thread subcriptions have cleared themselves twice!!!! grrrrrrrrr
InFaMouSLink
10-30-2015 09:43 AM
Eggs999bacon
09-24-2015 10:08 AM
