Hawk Pads as Brembo Replacement
Old 05-07-2005, 11:56 AM
GoBig's Avatar
Okay guys I just changed out my stock Brembo Pads w/ Hawks (http://www.import-racer.com/sku/HB453-585). Our Brembo braking systems are identical to thw Sub. WRX STI and Mitsu. Evo VIII. I also called Hawk to verify. Tire rack also recommends them however doesn't give model number (HB453-585).
I had 33,000 miles on the car and the brakes started sounding wierd (metal on metal), so I was thinking that they were worn. But when I pulled them it looked like they had another 5K miles to go. Can't explain why there was a metal/metal sound, maybe something was caught between the pad and the rotor.
Old 05-07-2005, 04:15 PM
cM3go's Avatar
Good to know, thanks for the info!
Old 05-08-2005, 10:27 AM
GoBig's Avatar
You might want to add this to the garage...or make it a sticky.
Old 05-08-2005, 02:54 PM
cM3go's Avatar
I wonder if the rotors on the same
Old 05-08-2005, 04:15 PM
GoBig's Avatar
Not sure, but if the bolt pattern is the same then yes.
BTW, these Hawk brakes are very quiet and stop extremly well!
Old 05-09-2005, 07:40 AM
deandorsey's Avatar
awesome info!
thanks
Old 05-09-2005, 12:02 PM
brahtw8's Avatar
The pads are the Hawk HPS, for High Performance Street.
I ran a set on my NSX for street/track duty and have since switched to Cobalt Friction GTs on that car, but the Hawk HPS should be fine for a TL and I'll consider using them when my original pads are used up (in a few months it would appear).
Old 05-09-2005, 10:38 PM
hondasaurus's Avatar
Nice work GoBig! I have the same metal/metal sound as though the brackets are sliding on the rotors. I have only 25,000 miles though.
Are the pads easy to install? Did you use a compressor to compressed the brake piston or do you twist the piston? (not sure if I'm using the right terminology). Also, did you change out the rear pads as well?
I'll try out those Hawks as well.
Old 05-10-2005, 01:55 AM
Powered by Guinness
Aegir's Avatar
Very good info! Many thanks for posting!
Old 05-10-2005, 06:52 AM
GoBig's Avatar
They were very easy to install.
Pull the old pad out and turn it 90 deg. so it's vertcal. Then use the old pad as a lever to gently push back the pistons, the rotor is the fulcrum. The pistons move slowly so be patient. Since the braking surface of the pad is up against the rotor, it will not harm the rotor because the pad is much softer than the rotor... assuming you have pad remaining.
I didn't change the rears. Usually rears last about twice as long, especially in front wheel drive cars.
Old 05-10-2005, 10:05 AM
SlntSam's Avatar
What's up with the brakes going so soon?
With my Prelude I tracked the car for two track days and just generally drove it hard and never had a problem. But with the TL my brakes are making that same metal to metal sound!
Old 05-10-2005, 10:40 AM
brahtw8's Avatar
I have 33.5k on my TL. I drive hard and brake hard.
My pads are still fine upon visual inspection. They are starting to make some noise, but not bad and they still bite. I should be able to get 35k, if not 40k out of them.
For an aggressive pad on big brakes that need to stop a 3500 pound car, I think that is pretty good. I hope I won't need to replace the rears for another 20k.
I would consider going OEM again, depending on how cheap I can get them compared to aftermarket pads like the Hawk HPS.
Old 05-10-2005, 10:56 AM
SlntSam's Avatar
I guess it's the price you pay for performance stuff.
Anyhow I got prices in $CDN for replacement pads and what not.
The Hawk part # above costs $150 for the pair
the OEM replacements are $225
I'm gunna get the hawks.
I had yesterday off so I went to the dealer to complain about rattles and my seat memory and the grinding noise.
They quoted $700 for the brakes and rotors changed. Now I'm wondering if the rotors even need changing at all.
Old 05-10-2005, 11:39 AM
SlntSam's Avatar
When I look at Tirerack.com I get this message where the hawk pads are listed.
NOTE: Ceramic pad material is recommended by the vehicle manufacturer and may have been supplied as Original Equipment. Replacing ceramic brake pads with pads of any other material may result in more brake dust or increased brake-related noise than originally installed pads.
Is this true? are the OEM pads ceramic?
Old 05-10-2005, 01:35 PM
GoBig's Avatar
I actually changed them a little prematurely, but w/ that grinding sound, could you blame me?
Old 05-12-2005, 11:14 AM
SlntSam's Avatar
Got my Hawk Pads yesterday and will install them on Friday.
Old 05-12-2005, 11:42 AM
GoBig's Avatar
Make sure you use the shims that come w/ the Brembos. You'll see them when you remove the Brembo pads.
Old 05-12-2005, 12:35 PM
SlntSam's Avatar
Will do, thanks for the heads up. You mentioned about the piston moving back slowly. Is it slower than normal brakes? You just used a c-clamp to push it back with the old pad right?
Old 05-12-2005, 01:25 PM
GoBig's Avatar
Take a screw driver and a towel. Place the towel over the roter. Then take the screw driver and place it in one of the penholes in the old pad and use the screw driver as a lever and the rotor as the fulcrum to pull the old pads out. Aleternating between penholes. When the pad is about 1/4 out, then pull it out by hand.
Old 05-16-2005, 02:12 PM
SSM 6MT
rstark's Avatar
How does the Hawk pads compare to the Brembo's for brake dust? Are they better?
Old 05-16-2005, 08:31 PM
GoBig's Avatar
I think there's less dust.
Old 05-17-2005, 12:46 PM
Wants an M3 in
ludachrisvt's Avatar
the hawk pads for the rears fit as well?
Old 05-17-2005, 01:03 PM
GoBig's Avatar
Yes, there are actually several manufacturers for the rears because it's a very common configuration. It's the same at the AT.
Old 06-12-2005, 04:32 PM
SSM 6MT
rstark's Avatar
I changed out my stock Brembo pads with the Hawk HPS on Friday. I bedded them in properly and they are great. I only had 10,000 miles on the car, but the Brembo pads were making a slight metal noise upon light braking and I couldn't stand the brake dust any longer.
In two days driving, there is significant less brake dust (including 8 x 60-10mph hard braking runs to bed in the pads) and the pads are very quiet. I just washed my car today so we'll see how the brake dust accumulates over the week. Thanks for the install tips!
Old 06-23-2005, 12:05 PM
Never Stock's Avatar
I checked in a Wagner brake catalog and it lists the 03-04 accord & the 04 tl as having Ceramic NAO pads. I think the NAO means non asbestos organic.
Tim
Old 06-23-2005, 07:08 PM
GoBig's Avatar
Tim
Hi Tim...I think those pads are for the OEM non 6MT brakes. The 6MT uses Brembo calipers which require a different pad. The Honda Accord does not use Brembo Pads or Calipers. The Hawks work great w/ the Brembo's.
Old 06-24-2005, 10:51 AM
Yes you are correct, I should have made it clear I was talking about the 5AT only. As a side note the 03-05 Accord Coupe 6 MT uses the same front brakes as the 04-05 TL 5AT.
Tim
Old 06-25-2005, 10:45 AM
kevin922's Avatar
Okay so i've re-done my pads 3 times now and i'm still having the same problem (squealing)
Attempt 1: Took the old pads off put the new pads on (with the shims from the brembo) - Breaks Squal.
Attempt 2: Didn't know I had to apply stopsqueak gook on the back so took the pads off and did that
Attempt 3: Determined i put the two "squeak" pads (the pads with the little metal noise maker on it) on the right and two non squeak pads on the left, so I re-did that..
At any rate i am still having a problem with light pressure <20 mph causing a bad squeaking sound.. any ideas?
Old 06-25-2005, 01:13 PM
6th Gear
RUTAKEN22's Avatar
Do the HAWK pads dust as much as OE?
Old 06-26-2005, 03:32 AM
SSM 6MT
rstark's Avatar
Did you bed in your brakes properly? Do a search on Yahoo/Google for bedding in new brakes.
Old 06-26-2005, 03:34 AM
SSM 6MT
rstark's Avatar
For a 6MT, absolutely not. I would say the brake dust is about 50% less (maybe even less). The rear brakes (stock pads) are hard to beat since they do not seem to dust at all.
Old 06-26-2005, 08:56 AM
6th Gear
RUTAKEN22's Avatar
Sweet, thanks for the info...
Old 06-26-2005, 03:55 PM
ejn184's Avatar
hi go big, if i wanna order for the hawk performance pads, i choose for 1 quantity right? im gonna order in tirerack.
Old 06-26-2005, 07:45 PM
GoBig's Avatar
Yes...order one and in the box you'll find 4-pads (2 for each rotor). Also, make sure you reuse the shims on the existing pads.
Old 07-05-2005, 09:55 AM
Ordered Hawks Pads
GoBig,
I got the pads as suggested by you. However, I'm having a hard time figuring out how to remove the pads. I can remove the caliper via the 2 bolts, but the pads are 4-ports which are connected to the caliper via 4 pins.
There are 4 10MM bolts that could be removed and open up the caliper to remove the pads. Is this the correct method? I don't recall having to do this before.
Thanks.
Old 07-05-2005, 10:13 AM
Administrator
Ron A's Avatar
Received 1,003 Likes on 573 Posts
Check out this thread from the 3G Garage
D-041: FRONT AND REAR BRAKE PAD INSPECTION AND REPLACEMENT
https://acurazine.com/forums/showthread.php?t=118283
Old 07-05-2005, 08:20 PM
GoBig's Avatar
GoBig,
Thanks.
When I did it, I just removed the two pens and the metal clip that holds the pads in. I then just use my fingers to move the pads/pistons back. Once there is room, just wiggle the pads out. When the pads are about 1/4 to 1/2 way out, use them to pry the psitons back a little more. This will allow the pad to come all the way out.
No 10mm bolts need to be removed for pad replacement. If you need to replace the rotors, that's a different story. However, my rotors were in great shape, so I didn't do a thing to them.
Old 07-06-2005, 02:26 PM
Special Tools?
GoBig,
Did you use any special tools as suggested in the replacement guide thread posted by Ron A?
Thanks.
Old 07-06-2005, 10:21 PM
GoBig's Avatar
GoBig,
Thanks.
Nope, just a small phillips screwdriver and hammer to push the pens out and a large flat headed screw driver to pry the brake out (upward). That's it.
Old 07-09-2005, 04:21 PM
ejn184's Avatar
hi GoBig, i already installed the HPS pads on front and rear , but it still have a noise when i hit the brake. but the braking is much better than the OEM. mine have 29500 KM.
Quick Reply: Hawk Pads as Brembo Replacement
