Greddy 03 Accord Strut Bar Installed
Old 03-13-2006 | 11:37 PM
ACCURATEin's Avatar
tehLEGOman
Greddy Strut Bar for 03+ Honda Accord
Part # 14053017
*Allows for EDFC motor clearance.
*Accord top hat modification - optional.
*Fits like a glove
Pictures:
Old 03-13-2006 | 11:44 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Question...(and not questioning your choice at all...looks dang good!)
Are the solid strut bars in any way better than the ones like this with the pivot point in it? Does the solid type make em any stiffer? The OEM is a solid type (no pivot joint) and the Neuspeed is the same way...but the greddy type has that pivot point in it? Does this effect anything at all? I ask because this is something I have always wondered. I do have one just like this mfg'd by Rod Millen on my Lexus GS....so I have experienced both and have always wondered this about these two basic strut bar designs and why they differed and what effect, if any, it might have?
Old 03-13-2006 | 11:50 PM
ACCURATEin's Avatar
tehLEGOman
To answer your question i'm not exactly sure which type of design provides more rigidity or less flex.
I would assume a one solid piece design will be less likely to bend or flex.
The 3 piece design with the end plates and middle connector allow for adjustability and are certainly easier to install.
Old 03-13-2006 | 11:54 PM
CTS-V Import Slayer
I hear ya on that one buddy! WOW....night and day! That Rod Millen one I put on was all warm and fuzzy when you got done and that damn neuspeed one just left you remembering how easy it was with the 3 peice design! But that was something I wondered about.....the ridgidity of the two in comparison to each other. You are running normal TL top hats with that bar too arent you!
Old 03-14-2006 | 12:02 AM
ACCURATEin's Avatar
tehLEGOman
Yeah man i'm really enjoying it.
I'm relieved to know that it actually fits on the TL and the install went smooth.
Two bolts on each side would certainly be optimal...but i will probably just run the car as is with the TL hats. Maybe one of these days i'll go ahead and switch out the hats for the accord version.
Old 03-14-2006 | 06:11 AM
bklynpanman's Avatar
321 whp SAE
nice man.. how does the car feel.. any less rigid?
Old 03-14-2006 | 07:56 AM
dan.....k's Avatar
Thanks for the info. Looks great!
Old 03-14-2006 | 03:29 PM
Meek32v6's Avatar
I like to whistle in my
Your engine bay = the goodness
beautiful. Wondering about how the car feels too with only one bolt on each size
Old 03-14-2006 | 11:02 PM
CleanCL's Avatar
for greddy, those mounting plates look a bit cheapo to me, and i'd be concerned about not having the 2 bolts in it and only the one, this may result in the bar flexing a bit. but good job on taking the chance on it. i personally would have painted the plates black... blue just looks off. or in your case, paint them white.
Old 03-14-2006 | 11:25 PM
ayethetiense's Avatar
.:KCCO:.
yes, it does look good. but would this not induce undeersteer on a front wheel drive car?
Old 03-15-2006 | 12:20 AM
CCColtsicehockey's Avatar
looks good man but I would really get the accord hats quickly as with only 1 bolt it can not be that good or safe.
Old 03-17-2006 | 05:35 AM
321 whp SAE
mine is installed with the accord top hats using both bolts!!! looks great
Old 03-18-2006 | 12:08 PM
pics pics
Old 03-18-2006 | 02:15 PM
CTS-V Import Slayer
Dude, you gotta get one of these things for your backseat!
Old 03-18-2006 | 03:20 PM
321 whp SAE
Fits Nicely with the accord top hats.. drilled 1 hole.. the hole to the left. that the bar uses
Old 03-18-2006 | 03:34 PM
CTS-V Import Slayer
Nice clean looking install!
Old 03-18-2006 | 04:42 PM
subinf's Avatar
One on the right for me
Looks good, glad there are some options to consider
Old 06-28-2006 | 02:36 AM
lookinco's Avatar
B A N N E D
did you touch up the open metal after u drill the hole? would there be problem with rusting?
Old 06-28-2006 | 08:04 AM
ACCURATEin's Avatar
tehLEGOman
I haven't drilled any holes yet. panman did, but i'm not sure if he coated the bare metal or not. I'm sure he'll respond.
Did you order the strut bar yet?
Old 06-28-2006 | 10:25 AM
321 whp SAE
some touch up paint.. that's about it.. should be ok i've checked, and no rusting
Old 06-28-2006 | 03:11 PM
lookinco's Avatar
B A N N E D
Yes I have the greddy strut and accord top hat, just about to install them.
Old 06-28-2006 | 06:21 PM
Kennedy's Avatar
OMGWTF4THGENTL
Is the top hat integrated into the strut? Will I need to dissaseble the strut to install the accord hat... I hate dealing with spring compressors.
Old 06-28-2006 | 08:30 PM
lookinco's Avatar
B A N N E D
Yes you would need to take apart the strut to install the Accord top hat, which means you would need the spring compressor.
Old 06-28-2006 | 10:04 PM
ACCURATEin's Avatar
tehLEGOman
Allright! Yeah you'll need to take those dampers out and install the accord top hats.
I think you'll like it..it looks real good and seems to work just fine when executing on and off ramps.
Old 06-28-2006 | 11:49 PM
lookinco's Avatar
B A N N E D
Accuratein, are you still using the Greddy strut bar with just one bolt on each end? If yes, do you think one bolt is enough?
I really don't feel good about drilling into the open metal, I don't want any chance of rusting. I was talking to a few shops, and one of them suggest building a new bracket on top of the 3 bolts of the damper and attach to the greddy bar.
Old 06-29-2006 | 02:01 AM
ACCURATEin's Avatar
tehLEGOman
yeah i'm still running one bolt on each side.
That's actually a good suggestion about making a bracket and welding it to the greddy bar.
Cusco might have something worth checking out.
Old 06-29-2006 | 04:48 AM
321 whp SAE
drill the hole .. jeez.. it's a hole
Old 07-06-2006 | 12:42 AM
ACCURATEin's Avatar
tehLEGOman
Accord Pillowball Upper Mounts
TEIN offers front and rear pillowball mounts for the CM5/CM7 Honda Accord.
These should be applicable on the UA6 TL.
Someone order these and confirm.
They should be goldish orange and say TEIN on them.
Part # PRA50-31S70
The second stud for the greddy strut bar should be there as well.
You're welcome!
Old 07-06-2006 | 01:15 AM
ACCURATEin's Avatar
tehLEGOman
The version on the left is what the pillowball mounts will look like...except it will have 5 studs for the fronts.
Old 07-06-2006 | 11:42 AM
twigglius's Avatar
Moved to the LOU
My local shop called their distributor and they were told that Tein will have a Pillowball SS system for our cars available in late August. Maybe I was misinformed???
Old 07-06-2006 | 10:50 PM
ACCURATEin's Avatar
tehLEGOman
Thats good news! i've been waiting for those to be released forever.
Old 07-06-2006 | 10:53 PM
lookinco's Avatar
B A N N E D
What's the advantage of running the pillow mount?
Old 07-07-2006 | 08:55 AM
Black_05_TL_6SP's Avatar
Ryan Christopher
From my understanding, pillow mounts are bad unless you are going to be autoXing the car. I am not 100% on this, but I rember reading that some where. Its better to stay with standard tops with a good urethane bushing. Please correct me if I am wrong on this.
I ordered my Accord top hats yesterday. I was just curious to know how much someone spent on the Accord ones??
Jason
Old 07-07-2006 | 11:31 AM
twigglius's Avatar
Moved to the LOU
Jason
I have also heard that they are bad because unless you are on the track they wear out very fast for the everyday driving.
Old 01-26-2007 | 02:58 PM
shayan's Avatar
My shop is having a hard time fitting the bar, I hope it works
Old 01-27-2007 | 01:38 AM
ACCURATEin's Avatar
tehLEGOman
I think they're pulling your leg and just messin with ya bud. This bar goes on like a charm. Are you having the coilovers installed at the same time?
Old 04-16-2007 | 07:54 PM
DiZlAoSbOiSoFlY's Avatar
Rock Chalk JayhawkZ
anyone else have the greddy strut bar? j/w because im thinking about purchasing one?
Old 04-16-2007 | 08:04 PM
hrglas's Avatar
2007 NBP TL
looks good. question......
what is the thing in the upper right corner that looks like a sock
Old 04-16-2007 | 08:51 PM
Meek32v6's Avatar
its a sock.lol....that catches your cars ball sweat
"The Spoon Sports Reservoir Tank Covers help keep your engine clean by absorbing master cylinder and clutch reservoir tank leaks. The high quality plush covers feature an embroidered Spoon insignia for durability. Made by Spoon Sports Japan."
Old 04-16-2007 | 09:37 PM
Kennedy's Avatar
OMGWTF4THGENTL
They're actually more like those mid 80's wristbands...
Quick Reply: Greddy 03 Accord Strut Bar Installed
