Exhaust mods
Originally Posted by aznbo187
Compilation of all stages of exhaust resonator modification.
So I took the time and made this post so all of the new people don't have to go through 20 pages of discussion.
So far, there are 4 stages of this exhaust mod.
Stage 1.
Least noticeable in exhaust note increase.
Configuration:
Stock exhaust.
Remove mid-muffler. Replace with 2.5" straight pipe. Everything else remains stock.
Cost: Can be anywhere from $30-$60 w/aluminized pipping.
Stage 2.
A tad louder than stage one, a bit more pronounced tone.
Configuration:
Stock exhaust.
Remove stock resonator. Replace with Magnaflow resonator part# 10416.
Magnaflow resonator is a 14" long resonator, which dampens and changes the note of the stock exhaust a bit more, thus you get a bit more loudness/tone.
Cost: Magnaflow resonator costs around $60. Install ranges from $60 -$90 w/ aluminized pipping.
Stage 3.
(Tone result TBA)
Stock exhaust.
Remove stock resonator. Replace with Dynomax resonator part# WLK-24215.
Dynomax resonator is a 12" long resonator, which is a bit shorter and less dampening than the magnaflow resonator, thus it should give you a bit more loudness/tone than stage 2.
Cost: Dynomax resonator costs around $40. Install ranges from $60 - $90 w/aluminized pipping.
Stage 4.
Loudest setup out of all 3. Has a bit of a rasp, similar to M3 exhaust setup.
Stock exhaust.
Remove Mid-muffler. Replace with a 2.5" straight pipe.
Remove stock resonator. Replace with a 2.5" straight pipe.
Cost: Can be anywhere from $40 - $60.
Note: If you live in a climate that is prone to rain, snow, rust, Stainless steel pipping is highly recommended.
This also does not prevent you from passing smog, as it does not alter the characteristics of the catalytic converters, but it does not mean that this is street legal either as it does alter the stock setup of the exhaust.
Media.
Stock Exhaust Configuration.
![](http://i43.photobucket.com/albums/e358/flydealz/Stock.jpg)
Stage 1.
![](http://i43.photobucket.com/albums/e358/flydealz/Mid-muffler.jpg)
Stage2.
![](http://i43.photobucket.com/albums/e358/flydealz/Stage2.jpg)
Stage3.
![](http://i43.photobucket.com/albums/e358/flydealz/dynomaxresonator.jpg)
Magnaflow Resonator 10416
![](http://i43.photobucket.com/albums/e358/flydealz/Magaflow.jpg)
Dynomax Resonator WLK-24215
![](http://i43.photobucket.com/albums/e358/flydealz/Dynomax.jpg)
Good luck!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
aznbo187
Quote:
Originally Posted by Toddy
Hope this helps. I labeled everything in Red for you
![](http://i95.photobucket.com/albums/l127/toddy_968/SEP4B0200.png)
found from this thread:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/removing-resonator-stock-exhaust-summary-post-1-1811-a-589747/
![](http://images.ibsrv.net/ibsrv/res/src:tl.acurazine.com/get/forums/images/maestro/buttons/viewpost.gif)
Stage 1.
Configuration:
Stock exhaust.
Stage 2.
Configuration:
Stock exhaust.
Stage 3.
(Tone result TBA)
Stock exhaust.
Stage 4.
Stock exhaust.
Media.
Stage 1.
Stage2.
Stage3.
Good luck!
aznbo187
BANNED
^hot damn it must've taken you forever to type all that out.
well done, sir!
well done, sir!
BANNED
wut.
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
All motor
Lol wut?
wat
BANNED
^you're welcome.
affect...it will cause
effect...it will be the result of
the sound will be affected by the effects of the new resonator.
quick answer is that yes, you can make your car sound like a G37 and it will pass emissions. Pero tienes que leer, nino!!!!
baynham (11-16-2012)
DerrickW
11-15-2015 05:52 PM
InFaMouSLink
10-27-2015 06:52 PM
joflewbyu2
10-08-2015 11:16 AM
