Excelerate Performance: TEIN Street Flex Now Available!!!!
Old 12-11-2013, 10:42 AM
Former Sponsor
Excelerate's Avatar
Excelerate Performance is excited to announce that the TEIN Street Flex is now available for the 3G TL (04-08). The Street Flex damper is the evolution of the popular Type Flex coilover. Developed to provide the ultimate balance of comfort and performance for both street driving and circuit use, along with wide-range damping force adjustment using our new Advance Needle technology and new damper valving specs, giving the driver a much more noticeable feel in damping force change and controllability. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Full-length adjustability offers separate spring preload and ride height adjustment. Updated internal components and external coatings increase durability and product life. Includes Pillowball Upper Mounts and is compatible with the EDFC and EDFC Active systems.
You can purchase them here: http://store.excelerateperformance.c...i-1875773.aspx
Additional Features
• Steel Construction
• Twin Tube Internal Construction
• Full-Length Adjustable via Threaded Body and Spring Seat/Seat Locks
• 16-Way Damping Adjustable (simultaneous compression and rebound)
• New Damper Valving Specifications for Improved Street Comfort
• Incorporated Advance Needle Design (nearly 200% improvement over predecessor)
• Pillowball Upper Mounts for increased steering feedback
• Camber Adjustable for Strut Type Front Suspensions
• Larger Piston Diameter (22mm O.D.) for Strut Type
• EDFC (Electronic Damping Force Controller)/EDFC Active Compatible
• Powdercoated Brackets and ZT Coated Shell case for Outstanding Rust Prevention
• One Year Warranty Against Manufacturer's Defects
Old 01-24-2014, 11:05 PM
3GTLCHICK's Avatar
Any sales coming up on these?
Old 01-28-2014, 05:48 PM
Former Sponsor
Excelerate's Avatar
The website pricing is pretty low, considering the newer coilovers are sold to us at less of a discount than previous coilovers. But PM me with your info and zip code and I'll see what I can do.
Old 04-27-2014, 03:39 PM
robocam's Avatar
What's the difference between the Street Flex and the Street Advance other than the Street Flex's ability to go slightly lower? Is one more comfortable than the other?
Old 05-06-2014, 12:46 PM
Former Sponsor
Excelerate's Avatar
The Street Flex is a fully threaded shock body. The TEIN SA are a partially threaded shock body and these reuse OE top mounts. The TEIN SF are more aggressive and suited for light track as well.
Old 05-08-2014, 10:40 AM
KingKong_Dav
kingkong_dav's Avatar
josh when are you going to throw out promo codes or discounts for memebers, it seem like your company is the only one charging full pop! i need discounts for random tech stuff
Old 05-09-2014, 01:48 PM
Former Sponsor
Excelerate's Avatar
None of the prices on our website are "full pop" and most of our prices are discounted on the website. PM me if you need a specific part.
The TEIN Street Flex are $1350 list and $1215 on the website.
GWEEDOspeedo
01-15-2016 10:39 PM
ExcelerateRep
10-14-2015 08:20 AM
jmaxima03
09-27-2015 10:22 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
Quick Reply: Excelerate Performance: TEIN Street Flex Now Available!!!!
