Engine Port & Polish, new Valves
#83
Originally Posted by jdmspec333
okay so i just put in my order for the 07 tl-s cams. my main worry is that if they will fit. as long as they fit, it can't be bad. i mean, they can't perform worse than the 04-06 cams, and even if it's not that much more lift or duration, the hollow cams, should free up some amount of power due to the lightweight and reduced inertia. i hope that made sense...
Speaking about hollow camshafts, the difference is absolutely immeasurable. That hollow part has very small diameter, it is not much of difference in weight, especially compared to the rest of rotating parts and cams are twice slower than crankshaft.
#84
well, since we are pissing in the guys Cheerios... I just thought of something.
I don't think the S cam has longer duration. It is a hard fact that a longer duration cam produces peak HP and peak torque at higher RPM than a cam with less duration. And, from the published specs for the TLS, it produces peak HP and peak torque at the same RPM as the regular J32 cam.
#85
.43g at 900+fps
well, according to the 07 tl service manual (oem), between the j32 and the j35, the lobe heights are different. now i know we discussed this before, the profile largely depends on the duration and lift, but stating that it has different lobe height, its gonna be a different cam altogether. like it was also stated before, honda likes to interchange parts between platforms. so why would they (besides the fact that they're hollow) use an entirely different cam with different profiles (the duration and lift still unknown) in a car with basically the same engine (just bored or stroked) when the old cam is tried and true? oh and before the cams are installed, i'm gonna have the machine shop figure out the lift and duration for both the cams (type s and non) before they are installed. this will benefit us all because i don't think there is anyone doing a cam only install, so dyno testing after the few of us doing the cam install will be worthless for a baseline cam comparison. oh yeah, is there a v6 adjustable cam gear out there? i've done a few adj cam gears on stock cams, and they made a small, yet noticeable difference. (sohc and dohc applications)
#88
Former Sponsor
#96
.43g at 900+fps
well its two grand for the first initial set because they have to program the machine, and dial in all the specs. they would probably go through a couple chunks of billet before they get a final production ready peice. it's like we're paying for r&d. the peices that come out after that would probably be around 150-200 each
#97
#98
'10 Hyundai Genesis Coupe
We should all pitch in for the cam gears, that would be a decent mod to do. Also I'm surprised you didn't port your Throttle Body Ussi, since you were messing with the heads, it would have been worth your while.
#102
So if UR sold the cam gears for 150$ it would end up being $200 for the first 40 customers to make up for the $2000 r&d and then $150 for everyone else. Someone make a thread.
I didn't know UR was so close to me, I'll have to visit them one day.
#103
.43g at 900+fps
well someone should go and find out. how much would it cost to make (x) amount of sets fo a certain price including the r&d. then we'd all split it evenly. we'd send the money directly to ur to build the pool up.
#104
Former Sponsor
#105
Ryan Christopher
Originally Posted by Excelerate
I have a good relationship with UR. I could get this produced like I did with the Acura TL stock size crakn pulley. However, I would need to see a list of at least 25 ppl that were really interested.
#107
I'll start the interest list:
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. HQTL6SPD
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
#108
#109
B A N N E D
So what performance gain does the cam gear gives?
Anyways I am down!
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. HQTL6SPD
6. lookinco
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
Anyways I am down!
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. HQTL6SPD
6. lookinco
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
#110
TL on 20's
I am in
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. HQTL6SPD
6. lookinco
7. keepin_it_clean
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. HQTL6SPD
6. lookinco
7. keepin_it_clean
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
#111
Fill this list and I will CNC them for you. $150 each. R&D will be on the house.
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. HQTL6SPD
6. lookinco
7. keepin_it_clean
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. HQTL6SPD
6. lookinco
7. keepin_it_clean
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
#112
hey who put me on the list!? lol i said if for $50, i'm buying a full brake kit from racing brake which is gonna leave me broke for a little bit, hopefully i can get back in if price is less, sorry!!
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. lookinco
6. keepin_it_clean
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
1. ussi
2. jdmspec333
3. Black_05_TL_6SP
4. Eoanou
5. lookinco
6. keepin_it_clean
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
#113
- Doc
1. papiowhisperer
#115
You guys are forgetting the cam and heads should be matched as a pair. If the heads are being ported, the cam will make a bigger differnence if it complements the heads. I would definately go with a bigger cam if I ported the heads. You also have to think about emissions. While bigger power can be made with more duration, it effects emissions much more than higher lift. Now on a larger displacement motor like the 3.5L you could get away with a proportionately longer duration without hurting emissions.
As for polishing or not polishing, these cars are fuel injected, not carbureted. Polish the hell out of the intake. You don't have to worry about fuel fallout like on carbureted motors. The fuel injectors are aimed right at the intake valves. Not only that but this is a 4 valve motor. You're going to have all the velocity and such that you need.
50-60hp is not out of the question NA and the gains will be larger for the already supercharged cars.
What's the point of cam gears on a stock motor? They allow adjustability. Why would you need to change the cam timing of a stock motor? If using aftermarket cams maybe but otherwise they're a complete waste of money. If you believe these work, go buy that tornado air thing while you're at it.
#116
Originally Posted by BLACKURA_NY
i think we should start a new thread for the UR cam gears, this way we dont hijack the port&polish
i wanna see the results from P&P and TL-S cams too!! dyno sheets PLEASE!
#117
Originally Posted by ussi
i agree, i was just waiting for someone to post all the advantages of the cam gears.
#118
By retarding camshafts you gain some power at higher rpm while loosing some at lower rpm.
#119
Originally Posted by I hate cars
Does the TL really need less low end torque? It's sort of lacking in stock form.
i was hoping more torque all around
