Endless BBK
Endless BBK
I was roaming around the endless wedsite and noticed they make a BBK for the 3rd gen TL.
Does anyone know anything about this kit. If it is a direct bolt on for an 08 TLS?
It looks to be a 6 Piston Caliper, with an Inch larger rotor.
I also saw that another member here had a Project Mu Kit. Was this a complete custom job, or does a RSX or TSX kit fit?
TSX fronts are the same to my knowledge
Originally Posted by stillhere153
More manual trans there is an adapter included
I dont understand what this means. I assume you ment "for"
Alright thanks for the help guys. I thought that maybe since the type s had the bbk on there, that the bolts might be in different locations.
Is that what you were trying to say. If I have the bbk from factory, I would need an adapter?
'06 750Li Sapphire/Creme
Originally Posted by Boosted_Brian
So, tsx fronts, are the same as the brembo's on the 08 TL-S?
So most kits should be a direct fit?
AZ Community Team
Received 7,770 Likes
Originally Posted by ndabunka
The TSX kits work on the AUTO tranny as a direct replacement. The auto has different connecting points (Knuckles) than the Manual tranny does. The TSX kits are great options for thos eof us with autos. If you have a manual, you may still have to fork out additional $'s.
Originally Posted by Bearcat94
Auto TL-S included or do they fall under the "same as the manual" category?
AcuraKidd
09-25-2015 11:18 PM
nuldabz
09-03-2015 05:49 PM
