Egr
Old Jul 4, 2009 | 05:14 PM
D-MacTL's Avatar
Egr
I would assume this is the proper place to post this subject. Is it true that if you clean your EGR ports and valves that will do your MPG some good and even the performance of your vehicle.
The EGR valve works by recirculating a 5-10% of an engine's exhaust gas back to the engine cylinders. Intermixing the incoming air with recirculated exhaust gas in a specific amount dilutes the mix with inert gas which slows the combustion, and lowers peak engine temperatures, resulting in more power and less hesitation under load.
If it is open when it is not supposed to be open - it can act like one monster vacuum leak and the engine will idle really roughly, stall or hesitate. If it doesn't open when it is supposed to open you experience detonation since the combustion chamber temperature will be higher than normal resulting in lack of power and response.
Old Jul 4, 2009 | 07:08 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
since your car is an 04... cleaning the egr valve wouldn't hurt
Old Jul 4, 2009 | 07:22 PM
Opel's Avatar
EGR only works while your cruising..... it stays off at idle and under WOT.... its role is to lower combustion temps which skyrocket while ur crusing, because thats when your car runs lean the most, which results in higher temps...at cruise, ur ECU will adjust a lean a/f ratio for better fuel economy.
If EGR is on during idle, stumble and even stalling will likely result. If EGR is on during hard acceleration, low power (from reduced air/fuel volume) is the result. At part load, lean mixtures for economy create high combustion chamber temperatures and without EGR, these conditions not only create Nox, they also foster pre-ignition and pinking.
just figured id detail it a bit
keep it clean...
Old Jul 4, 2009 | 07:34 PM
D-MacTL's Avatar
keep it clean...
Is that a TL with the 370 WHP?
Old Jul 4, 2009 | 09:53 PM
I hate cars's Avatar
keep it clean...
EGR is only for emissions. It lowers combustion temps to reduce NOx emissions.
To combat the associated power loss when egr is active there's usually a bump in timing whenever it's in use. This is why it's important to keep it functioning. The extra timing will cause detonation.
Just wanted to clarify that EGR is not for anything but for emissions but since the ECM is programmed to run with it, if it stops working there will be drivability issues.
Old Jul 5, 2009 | 10:57 AM
Opel's Avatar
Yes it is... 04 6MT TL
Old Jul 6, 2009 | 10:05 AM
Supercharged? Just wondering, you don't happen to own an Opel, do you?
Old Jul 6, 2009 | 11:13 AM
Opel's Avatar
yes supercharged...and no opel. lol
Old Jul 6, 2009 | 11:48 AM
myron's Avatar
so speaking about EGR port clelaning, is the procedure the same as on the 2G TL? I did it on my 2G before so I know it's not hard. From the looks of it, it's the same I just don't want any surprises.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
pstomps
Feb 20, 2017 03:29 AM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
ibGTV
Sep 28, 2015 03:40 AM
prbori
Sep 27, 2015 01:37 AM
