DUAL Exhaust VS SINGLE Exhaust
94 DC4 RS LSV/Turbo
1. I felt a little better low end pull w/ the single exit, and it weighs far less than a dual
2. You definitely gain some low end torque when combined w/ other parts such as precat deletes and jpipe
3. It is most certainly quieter in the cabin as the gasses are traveling faster and out of the passenger side, outside: its not overwhelmingly loud like say the greddy evo2... if your windows are down you can hear the scream while wide open, but cruising speed it is fairly inaudible
In a single exhaust, there is less surface-friction for the exhaust pulses to drag against. I'm not an expert in this field, but I'll try to make it understandable the way I learned it (with image!). When you analyze the velocity inside an exhaust pipe, you have the constant velocity, and then you have the boundary layer. The boundary layer is the distance between the pipe wall (velocity 0) and constant velocity (inviscid region). From the velocity profile you can see as the flow deviates further away from the wall, there is less resistance on the exhaust gas, thus maximizing flow.
When adding a Y-pipe and a second pipe for the dual exhaust, you are increasing the boundary layer. Therefore you have less gas flowing at maximum velocity. Not to mention as Al said, one less canister saves you a few pounds.
But again, this is all theory, and the Y-Pipe and extension for the dual exhaust on the TL isn't too much added length realistically speaking.
Sound wise, there is more muffling area the gasses pass through in a dual exhaust system, making the dual exhaust a quieter system.
08_UA7_Gr33k
02-11-2016 02:17 PM
InFaMouSLink
10-30-2015 09:43 AM
joflewbyu2
10-08-2015 11:16 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
AcuraKidd
09-25-2015 11:18 PM
