The Drone is unreal! Help!
#84
I dont know about you guys, but on certain days, my drone is not that bad, but on others, is just damn near head shattering. I have a feeling i fucked up somewhere on the install, where the hangers have pinned themselves on the rubber to cause an over amount of resonance...
#85
I'm thinking the cone isn't what we want anyway. Sounds like it would restrict exhaust flow... Good luck j1n. It was good to see your pictures b/c I had never seen the OEM resonator. Mine came with a hacked off stage 4 exhaust. Based on that, I'm thinking this magnaflow muffler is gonna work. How do they compare on the inside? Perforated metal pipe with packing?
BTW: Are you neglecting your OEM Type-S wheels?
lol yes those are my type s OEM wheels just sitting in my garage. ive been thinking about selling them but not sure if i will.
ankur914 when did you get the cone? did you ask josh for it or did it just come in th mail?
#86
If anyone is in the chicago area in need of a custom exhaust shop that welds and deals with stainless steel, i guess Iggy's Muffler Shop is it...I have no experience with them, but from the online yelp reviews, they seem to be a good shop. Im going to be going there tommorow.
#88
It arrived yesterday. It was from B&B. Im pretty sure its from Josh's efforts to address our concerns. I surely didnt expect it to arrive yesterday, but it was a nice surpise
....my only problem now if finding a damn exhaust shop in chicago that is good with welding & handling stainless steel.
i was thinking about getting a small muffler like the one on the CT and using the magnaflow one right behind the test pipe. but that might be a bit much. i dont want to completely silence the exhaust i just dont want drone.
#89
Former Sponsor
The resonator cone doesn't really reduce hp; they've tested them before. It's designed to reduce resonance. I've asked BB to send all the resonated customers resonator cones.
The cone goes in the front pipe after the resonator and the tip of the cone faces the front of the car. You will want to have the cone tack welded in place.
#90
did you know it was being sent to you? i would like to get the cone if it helps.
Im hoping to get it installed tomorrow. I will definitely post my experience once i have it done.
FYI, if you google "B&B drone" - a thread about CTS's having the drone pops up. Some members installed a dynatech vortex cone in their systems and stated that it helped reduce drone. I hypothesize that these cones will do the same for us, eventhough they are not as large as the dynatechs.
#91
Guess i'll have to wait for the cone before moving forward with the magnaflow.
#93
#95
94 DC4 RS LSV/Turbo
only if it were more cost friendly... $105 is a bit much
magnaflow 14148 $105
![](http://www.smartchamp.com/ebay/magnaflow/images/14148.jpg)
magnaflow 14158 $105
#96
Former Sponsor
^^ Yessir, the first one is it, notice that it is a bit smaller in dimensions to the Comptech one so it shouldnt kill the exhaust note to a point where you cant hear it.
The above cone may resolve the resonance issue but if the exhaust is still too loud for you then get the mid muffler. The long 4/5/6" diameter mufflers dont tend to reduce noise as much as the oval shaped due to the lack of packing material depth. A 5" round mid muffler with 2.5" pipe has only 1"~1.20" inch of packing material to reduce noise, compare that to a 5" X 8" oval one which, towards the sides, has as much as 2.75" of packing material, the depth of the material is what will reduce noise and resonance. This is proved and tested with the CT exhaust as the primary mufflers are even smaller than the XLR8 and ATLP mufflers but the mid muffler is where all the noise/resonance reduction happens.
#100
Got the resonator cone installed. The drone does seem to be cut out a bit. I would say about 30-40%. Its still present, but right now, i think I can live with it. Unfortunately, chicago afternoon traffic is a bitch. I could barely hold a constant speed above 65 mph..with all the gassing and coasting. At 50 -60 mph, the drone was toned down to tolerable. Under these conditions, i found the drone with the resonator cone tolerable. And, I didnt have to really raise my voice to talk (to myself...).
Later tonight, I will drive I-94 where i can hold a 80 mph speed constant.
I have a question for you all thou. After installing this exhaust system, i find that my car doesnt like to enter into 5th gear when driving around 40-45 mph, and holds revs at 1900-2000 RPMs. Does this happen to anyone else?
#101
40-45 is ussually when i shifts into 5th for me. when im decelerating it ussually down shifts at 39/40 MPH to 4th.
#102
94 DC4 RS LSV/Turbo
dunno I think the mufflers jnc mentioned might work... best bet would be to install one on a non resonated setup and have a user review it... ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I have seen those race muffelrs in person... and it was on a straight pipe 3" k series civic... wasn't that loud... weird
#103
I Have A Meth Lab In
Gilla, where are you? I replied to your PM, am having the same issues. I already have a high flow J-pipe (ATLP V2) so your drone is at least as bad as mine.
Let me know what happens on your install if you get the MagnaFlow. This drone sucks.
#104
#110
Some times when I am in the car by myself, I forget to put the music on b/c I am in an exhaust drone trance. I do realy like the sound, except when any of the other 4 seats are filled.
I'm gonna jack the car up this weekend, take some measurements, and then order THIS, assuming it fits somewhere. Even if the cone arrives before, I'm not gonna stick it in. I'd rather not put a restriction right in the middle of the pipe.
#111
#112
Chapter Leader (San Antonio)
You guys should've bought the Comptech Exhaust and slapped on a Aero Resonator, very little drone, and at the same time not too loud in cabin. Anyways, I find it funny that one user said he had customers in his car with an exhaust... If you're going to have customers in your car, don't buy something that will make more noise.
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
#113
i know what you mean. i dont mind it at all when im by myself... mostly because i barely hear it anyways cause im bumpin my music. but when i have passengers and the music is down and your trying to have a conversation the drone is annoying.
i will post before and after audio clips when i do it...... im still waiting on that cone!!!!
#114
Okay, so I have to put my 2 cents into this, being that I have the Xcel Resonated version. Every fix I look at seems to restrict flow. The CC inserts have a small interior and holes on the outside, and the cone is, again, more metal with some holes.
Excel says it's been tested so I'll try the cone (if I get it). I'm a little hesitant to put an additional muffler on. We bought this type of exhaust to get more flow and hp to begin with, so I'm waiting to hear from everyone who straps on their choice.....
#115
#118
The Vibrant resonator is 2.5" inlet/outlet (obviously) with overall length of 14". Resonator itself is 4.5" x 6.75" Oval with 10" body. It's basically the mid-muffler that we're looking for, IMO. I'm gonna leave the resonator alone and put this downstream, assuming it will fit downstream. It is a straight through design, eg: no physical path restrictions like the cone.
#120
On cold startup, the drone is not annoyingly loud anymore. Before when i used to start up the car in the garage (with the damn door open lol), our dinner plates, wall fixings, and such would rattle in the kitchen (attached garage). After the cone install, not so much.
The incabin drone of cold start up is also significantly reduced.
Prior to the entire exhaust installation, i had a vibration free car (after one dealer visit to cure the rear deck rattle...which by the way, Libertyville Acura rocks). After the exhaust install, pre-resonator cone install..well...There were too many rattles that i couldnt count. ONe in the center console, one in the passenger side door, one in the drivers side seat belt pillar, another in the damn dash which seemed to be coming from way inside the dash.
Well, after the resonator cone install, all the vibrations aside from the center console rattle were all eliminated. Less resonance produced by cone downstream of resonator is what i surmise. Additionally, when crusing at 80 mph, i dont get a headache. Dont get me wrong, there is still low frequency drone present, but it doesnt feel like your head is going to pop off. I can enjoy music at a volume of 10 now also.
In terms of power loss, the ole butt dyno didnt feel any sort of loss at all.
Many people stated that after the resonator cone was installed, the drone was not annoying anymore. It is now definintely tolerable, and at times, nice to listen to. People can hold a conversation in the car as well.
All in all, i now love the exhaust. I dont think i would change anything on it. It sounds great outside of the car, and pretty dope on the inside. I will say that after 200 miles, i have started to get used to the sound, but the resonator cone did make a difference. I hope this helps in evaluating your decision.
