does any one have the link?
so ive been trying to search for it for the last 30 mins, maybe im putting it in wrong in the search engine, but i remember there was a sticky for the 3 different stages of what you can do for the stock exhaust, was wondering if anyone can point me to right direction, i have to head out and wont be back late so i dont want to do late searchings lol
https://acurazine.com/forums/showpos...&postcount=531
Compilation of all stages of exhaust resonator modification.
So I took the time and made this post so all of the new people don't have to go through 20 pages of discussion.
So far, there are 4 stages of this exhaust mod.
Stage 1.
Least noticeable in exhaust note increase.
Configuration:
Stock exhaust.
Remove mid-muffler. Replace with 2.5" straight pipe. Everything else remains stock.
Cost: Can be anywhere from $30-$60 w/aluminized pipping.
Stage 2.
A tad louder than stage one, a bit more pronounced tone.
Configuration:
Stock exhaust.
Remove stock resonator. Replace with Magnaflow resonator part# 10416.
Magnaflow resonator is a 14" long resonator, which dampens and changes the note of the stock exhaust a bit more, thus you get a bit more loudness/tone.
Cost: Magnaflow resonator costs around $60. Install ranges from $60 -$90 w/ aluminized pipping.
Stage 3.
(Tone result TBA)
Stock exhaust.
Remove stock resonator. Replace with Dynomax resonator part# WLK-24215.
Dynomax resonator is a 12" long resonator, which is a bit shorter and less dampening than the magnaflow resonator, thus it should give you a bit more loudness/tone than stage 2.
Cost: Dynomax resonator costs around $40. Install ranges from $60 - $90 w/aluminized pipping.
Stage 4.
Loudest setup out of all 3. Has a bit of a rasp, similar to M3 exhaust setup.
Stock exhaust.
Remove Mid-muffler. Replace with a 2.5" straight pipe.
Remove stock resonator. Replace with a 2.5" straight pipe.
Cost: Can be anywhere from $40 - $60.
Note: If you live in a climate that is prone to rain, snow, rust, Stainless steel pipping is highly recommended.
This also does not prevent you from passing smog, as it does not alter the characteristics of the catalytic converters, but it does not mean that this is street legal either as it does alter the stock setup of the exhaust.
Media.
Stage 1: Revving
Stage 1: Revving
Stage 2: Revving
Stage 2: Revving Pt.2
Stage 2: Inside Revving
Stage 2: Drive By
Stage 3: Windows Down Driving
Stage 3: Revving
Stage 3: Drive By 1
Stage 3: Drive By 2
Stage 3: 2007 TL-S all-in-one
Stage 4: Revving
Stock Exhaust Configuration.
Stage 1.
Stage2.
Stage3.
Magnaflow Resonator 10416
Dynomax Resonator WLK-24215
Good luck!
aznbo187
Stage 1.
Configuration:
Stock exhaust.
Stage 2.
Configuration:
Stock exhaust.
Stage 3.
(Tone result TBA)
Stock exhaust.
Stage 4.
Stock exhaust.
Media.
Stage 1: Revving
Stage 1: Revving
Stage 2: Revving
Stage 2: Drive By
Stage 3: Revving
Stage 3: Drive By 1
Stage 3: Drive By 2
Stage 4: Revving
Stage 1.
Stage2.
Stage3.
Good luck!
aznbo187
rcs86
08-02-2016 07:52 PM
lanechanger
10-13-2015 11:56 AM
