You are the man!!
Originally Posted by 6spd-GERCO
(Post 15698318)
So are there no turbo manifolds sold right now? are all of them custom made?
Not for the TL. Although he is not doing a TL build since he has an Accord. Very similar build.
Originally Posted by Hi speed
(Post 15700051)
https://www.heeltoeauto.com/p2r-j-se...ines-p390.html |
Originally Posted by JacobT
(Post 15700073)
For making a custom manifold do you think it would be easier to chop up some oem precats? or buy a flange like this and go from there?
https://www.heeltoeauto.com/p2r-j-se...ines-p390.html If you go through the thread, Ken posted pics of his setup - it bolts to the precats and has an up pipe, similar to how Subarus are done. That's how I intend to do mine as well, and similar to how Tony the Tiger did a customer's. |
Originally Posted by screaminz28
(Post 15700123)
That's the type of flanges that Utah used on his. Another option is to use flanges from Prank (or cut stock J-pipe flanges) and make the piping route from the precats to an up-pipe.
If you go through the thread, Ken posted pics of his setup - it bolts to the precats and has an up pipe, similar to how Subarus are done. That's how I intend to do mine as well, and similar to how Tony the Tiger did a customer's. https://cimg6.ibsrv.net/gimg/acurazi...75c80fd6dd.jpg |
You could do it that way, or just cut off the pipes right at the mating flange and use the flanges with your own pipe. Like Ken's:
https://cimg8.ibsrv.net/gimg/acurazi...9c219046d4.jpg Using the stock J-pipe is just a method to have free flanges. The set is only 60 bucks from Prank Parts for brand new stainless flanges. |
(Post 15700252)
get a second car if you plan to turbo. A lot of things need to be hashed out..
I might be putting up the turbo kit for sale. Issues came up with the wife CRV so it is going to need some major repairs done...
just bought 5 tires for the crv since I had a puncture 1/4 mile from my apt... Spare tire was also shot... Tire couldn't be repaired since it was too close to the side walls. Thank god discounttiredirect is having a 100 off 400 deal...
Also I will be closely monitoring the crv engine. Had an overheating issue when the upper coolant hose blew off. Didn't know how long it had occurred since I was driving for over an hour before I stop... Temp gauge didn't go up until I parked the car. So far no coolant mixed into the oil. Going to need to flush the coolant and install another thermostat just for preventative measures. hopefully it won't need the head milled and a new headgasket. (cross finger). If it comes down to that then I am going to put in a low millage k24a1. car has over 215k on it and it rusty. |
:sad:
Originally Posted by teh CL
(Post 15701901)
:sad:
well battery light on the CRV just came on... So either the alternator or battery... It just gets better and better. I haven't even touch my car yet.
Damn, I'm feelin it for ya. I have a 25% off coupon at Advance if you need it. Not a ton, but if you're getting a battery or alternator it can save a few bucks. I also have a $20 off $40 speed perks if you can use it. PM me or hit me up on FB.
Got it off now pray for me that the exhaust shop can weld on the nut and break it out.
https://cimg3.ibsrv.net/gimg/acurazi...ae5e099d4f.jpg |
4 shops , 20 buck, and 4.5 hours later.... The car is kinda sorta put back. Had then punch out all 3 studs. The unbroken one had jacked up threads. So the j pipe is held on with 2 bolts in the rear and the cat back is also held on with 2 bolts.. Yeah I am done with this bull shit. Going to be until may or if not next year. All the fucken cars decided to break all at once. I was so close to getting a rental
On the flip side. The rear cat looks good even though the media was kinda loose. I give it a hard smack and now it stays in place again. There was some Ca deposits or something. Could be from when I was using wiper wash for water/meth. They just flaked right off after I touched it |
Was the CRV ever maintained? :rofl:
Cars make and break dreams.. |
(Post 15702208)
looking for an oil pan again... I think this time I will just buy new, and do the none welding oil return
Originally Posted by thisaznboi88
(Post 15702497)
Sorry to hear of the problems, that's just the way it goes, don't get discouraged or bang your head on the wall just take your time and it will come together |
(Post 15702497)
I guess you could drill a hole and thread it and then jb weld that. Seems to be a common method without issues. |
I used a AN bulkhead fitting. Cut off the shorter end and used two teflon washers and hondabond/red locktite. I peened the nut/threads in several places to make sure it doesn't come off.
Rodney's kit came that way and I haven't had any problems with it leaking or loosening up. |
I was looking for something like this
http://www.ebay.com/itm/Turbo-Oil-Pan-Oil-Return-Drain-Plug-Adapter-Bung-Fitting-10AN-no-Weld/301795904211?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140211132617%26meid%3Db750fa26541643fe93c017e28a706e1a%26pid%3D100085%26rk%3D3%26rkt%3D4%26sd%3D251669833365%26clkid%3D3986516097609560020&_qi=RTM2247627 |
(Post 15702868)
Turbo Oil Pan Oil Return Drain Plug Adapter Bung Fitting 10AN No Weld | eBay |
Utah is right. It looks like that one is made for a steel pan.
I've seen many successful oil drain fittings using the straight-cut NPT threads for the pan on one side and the male AN on the other for the drain tube. This is generally done using black RTV as sort of a "thread sealant" as the black is less susceptible to oil deterioration than all other sealants. Just make sure there is absolutely no oil residue on the pan when installing the fitting. Rarely will this setup leak if the fittings hex is held stationary when tightening the line onto it. Once the fitting is moved after being installed, the RTV's seal is broken and will begin to leak. Some people even install the drain line before the RTV dries to prevent this from happening but if you're careful enough, you will be fine.
I think I am just going to cut off the AN fitting and weld the hole, then relocate the drain nozzle. Doesn't look like this oil pan will sell and I hate to trash it
bought a new oil pan for 60 shipped. Just need another bung and pay more labor to get it welded again because I want boost!!
also just realized that rv6-p sells those studs way cheap than honda. Honda chopped me @ 12 bucks a stud...
So new j-pipe gasket and a few extra studs are on order |
12 bucks a stud ouch that's why I'm a hoarder at work and strip all the bolts off of cores and junk parts I can't think of the last time I had to buy a bolt it's been years,
When are you going to re-start the install ? |
I am shooting for first Thursday of may.
Originally Posted by UTAH TSX
(Post 15716960)
Oil pan shipped today. Not sure if April fools joke or actually shipped
Bought another 10An oil return fitting. Just going to get it welded again. Going to double check it on the car first so I can make a reference on where I want it on the new oil pan
Contacted Paul about installing everything and fabricating the brackets for the intercooler. Hopefully I can get it all done and under budget by may.
I also acquired an LSD from a Tl to put in my accord tranney. |
Wait, youre paying someone else to do the install for you? Seems to me like you have plenty of knowledge and capability of doing this yourself. You would be surprised how easy it all really is. Sometimes i wonder which part of it all i truly enjoy the most. Sure, i enjoy daily driving a 450 horse Accord. But man, theres really something about the build and construction that gets me amped up. Maybe thats why ive had damn near every displacement known in the j-series family in the car in roughly 3 years or so? Lmao.
I say at least make an attempt at it. YOU CAN.DO IT!!! ;) |
lol fine Ill try to do it. It might be a little half ass with mounting the intercooler. I actually want to have all the intercooler piping welded so that I don't have to worry about it blowing off the coupler during boost. Its also a pain in the ass to work in front of my Apt parking lot. The concrete isn't even straight and slanted at a small angle. I wish I had a rack that I could rent out for a day or two like they do back home in Cali
(Post 15727527)
I vote for diy as well. I don't care who does the work, but a turbo kit install isn't like a supercharger where it's a known time to install, so there will always be unexpected things. Unexpected means more time, which means more money. If you were quoted a flat price for these install, I wouldn't trust it, even if it was from your best friend. |
Alright diy it is!
