DIY: Innovative engine mounts - SIDE ONLY
takin care of Business in
Well the weather was nice and sunny out.....and Innovative mounts have been sitting in my basement since a while so thought why not
What is Innovative mounts ???
SHIT LOAD of info here....
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/innovative-mounts-review-683990/
Would like to thank everybody on this above mentioned thread....
Where to buy them ???
Josh from Excelerate would be the answer
Am just doing a write up with lots of pix for the side mounts....I will install the front and the rear prolly over the weekend and ask mods to merge the threads.....
Its my first DIY write-up....here we go
First off....all the tools you would need:
Now this is how things look:
The zoomed images of the lower 2 bolts
The bolt 4 is hidden behind the ps reservoir so take it to a side
Now that you can see all the bolts in your face like DAYLIGHT....take them out....start with the ground wire bolt....
Then prep your Innovative mount by tightening the center bolt....some people usually do that at 30lb/ft....some just hand tighten them.....this is how it should look....
Now put the new mount in place....dont tighten the bolts yet....
Imaginary view for the ground wire....(i misspelled "imagine" in the picture
Now that you have everything in place tighten the bolts and you DONE !!!!
This is how it will look:
Swing back the ps reservoir in place
I just opened the stock mount and this is how it looked
Enjoy !!!
Enjoy !!!
wow the side one really does seem EASY! just unbolting and then bolting! that's awesome. does this side one have a vac line that i need to worry about? totally doing this over the weekend...! how'd the other 2 go?!
i havent gotten a chance to go over the other 2 yet.....will be doing it over this coming weekend.....will do a little write up there too
Also, please be aware of this potential problem during the install....
Innovative SIDE Mount Install Advice (click here)
sockr1
Oct 1, 2015 01:31 AM
