Custom Quad-Tips Axle-back for base 3G A-Spec
Long time lurker, don't post much. Just wanted to share the custom quad axle-back I got done on the gf's base 3g with a-spec rear. Came out looking similar to the ATLP quads. Results below. labor was around $300 and $45 each for the ebay mufflers. Just wanted to share for those wanting exhaust options w/o spending an arm and a leg for full catback. Results below
GKinColo08TL (12-10-2013)
if you're referring to a normal downward angled cut, I felt it didn't look right with the staggered/offset look. If you're referring to the sideway angle like the Type-S, as much as I like that look, I wanted to avoid doing a 'type-s' exhaust.
[QUOTE=Ratm68;14720204]Long time lurker, don't post much. Just wanted to share the custom quad axle-back I got done on the gf's base 3g with a-spec rear. Came out looking similar to the ATLP quads. Results below. labor was around $300 and $45 each for the ebay mufflers. Just wanted to share for those wanting exhaust options w/o spending an arm and a leg for full catback. Results below
What muffler?
How does it sound?
What muffler?
How does it sound?
I don't have any sound clips, plus i find most 'sound' clips to be nothing more than misleading when it comes to deciding on exhaust. the mufflers were cheap ebay universal, had i known that I had to redo the tips, probably would have went for a magnaflow
http://www.ebay.com/itm/Universal-3-Dual-Burn-Tip-Stainless-Steel-Exhaust-Resonator-Muffler-2-5-Inlet-/370959747232?pt=Motors_Car_Truck_Parts_Accessories&hash=item565eec88a0&vxp=mtr
Ciroqboy (12-10-2013)
Universal 3" Dual Burn Tip Stainless Steel Exhaust Resonator Muffler 2 5" Inlet | eBay
But looks good, think I'll try it
Go with whichever you find best.
I know I like the OEM exhaust tip best, but extended further out.
The following 2 users liked this post by guitarplayer16:
Ciroqboy (12-10-2013),
story.customz (12-11-2013)
most muffler comes with 3" tips, even sitting flushed next to each other, the dual 3"s wouldn't fit in the a-spec 3.6"ish opening. We ended up ditching the 3" and simply polished up some 2.25" pipes and welded/angled them closer to each other to clear the slot.
The biggest problem with the TL's exhaust and bumper is the clearance and how the opening is angled(which IMO, makes single tips looks bad, hence the oem tip is angled as is the type-s with the offset). Most muffler needs to sit at an angle and most tips needs to be extended. So regardless, most muffler you buy, will need some custom welding of the tips or it will likely be tucked in. If you want single tip, just go for one of the vendor's or get whatever topspeed knock-off for $500 and call it a day.
Ciroqboy (12-13-2013)
Amazing
Team Logik
[QUOTE=Ciroqboy;14766471]
Hey what ebay mufflers did you buy? If you could let me know please! This is the exact type setup I am looking for.
What muffler?
How does it sound?
What muffler?
How does it sound?
http://www.ebay.com/itm/Universal-3-Dual-Tip-T-304-Stainless-Steel-Exhaust-Resonator-Muffler-2-5-Inlet-/300998133772?pt=Motors_Car_Truck_Parts_Accessories&hash=item4614e3080c&vxp=mtr
I got the one with the fake titanium burnt tips with the intention of them fitting in the a-spec. I'd recommend going with a universal magnaflow or dynamax some name brand bc the cheap ebay ones have really thin walls and drones comes through the cabin easier.
ExcelerateRep
10-14-2015 08:20 AM
4drviper
09-23-2015 07:42 PM
