Correct Brake Pads, Non Type S question
Morning from Florida ladies and Gents,
I am looking for Brake pads, for my 2005 Acura TL 6 speed, but it's not the normal brakes. I came with Brembo 4 piston Calipers, what pads do I need, that will fit?
I don't want to order the wrong one? If you can point me in the right direction I would appreciate it, or a thread I missed. Also, what do you recommend if I want to step up in stopping power?
I do have cross drilled and slotted rotors that came with the car.
Thank you in Advance,
https://acurazine.com/forums/third-g...ep-a60-945615/
SerpentX (09-13-2018)
Plenty of threads talking about brake pad options out there. Your MT uses the same pads as a Type-S. You will need to figure out your balance regarding price, dust, initial bite, and durability since there are a stupid amount of variance of opinions here. If you search for CMAX, you generally will stumble upon the various pad threads since that is one of the well used options for those that put price, dust, and durability higher. Again...soooooooooooooo many options and opinions out there.
Here is a start
Here is a start
@breezy, I will get back to you on that after work. Is that the same shape as the ones in front look? instead of the normal oblong curve pads normally found for economy brake pads?
I'll PM you on the rear pads once I make a decision.
See the pads in this link? and how they look, that's what I need for the front Brembo 4 piston setup correct?
https://www.acurapartswarehouse.com/oem/acura~pad~set~fr~45022-sep-a60.html
https://www.amazon.com/Genuine-Acura-45022-SEP-A60-Brake-Front/dp/B00FZNCA96/ref=pd_sbs_263_2?_encoding=UTF8&pd_rd_i=B00FZNCA96 &pd_rd_r=cf4162ea-b777-11e8-b560-8d045d38d0f1&pd_rd_w=epdCm&pd_rd_wg=bYx2T&pf_rd_i= desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=801797198332880 1850&pf_rd_r=R9SS51DM7ASPTYBW063F&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=R9SS51DM7ASPTYBW06 3F
Not these oblong curved ones?
I will jack the car up and check this weekend, just curious. I am about to help my parents change brakes and rotors on my moms 350z, and done pads like 5 times on other cars. Haven't on the TL as I just bought it last year.
Last edited by SerpentX; 09-13-2018 at 12:15 PM. Reason: Added another link and some text
https://www.acurapartswarehouse.com/...2-sep-a60.html
https://www.amazon.com/Genuine-Acura.../dp/B00FZNC3X4
The A60 is right, A10 is not.
handsom-hustla
03-08-2013 12:55 PM
csmeance
05-12-2011 05:14 PM
VegasRPh
08-31-2010 01:42 AM
miked8887
Dating & Relationships
42
01-08-2009 09:24 AM
JeffTSX
22
09-16-2004 10:54 AM
