contact points
Old Apr 24, 2006 | 09:14 PM
joed40's Avatar
05WDP Midlife crisis
contact points
Okay folks need a little help here. Will be installing grounding system this w/e. I have three points to connect to. What/where are they??? engine/body/transmission???? What points/ bolts do I connect to?? Looking for time savers here.
Old Apr 24, 2006 | 09:23 PM
05TLTony's Avatar
Dr. Feelgood
What's up Joe? Getting addicted to mods huh?
The points I grounded were transmission, altenator, throttle body, factory ground and all these to the negative of battery. I had another ground point, but forgot what it was. Too lazy to go downstairs to check. I think trans, alternator and throttle body will be okay.
Oh, whatever you do, do not unscrew the bolt holding the altenator in place. It's a pain to put back!
Old Apr 24, 2006 | 09:28 PM
05TLTony's Avatar
Dr. Feelgood
Joe,
check Ken's thread on photos. He installed his buddy club ground kit. I believe he showed the contact points.
Old Apr 25, 2006 | 07:56 AM
gqchicago's Avatar
5mins2disney.com
I just did the same install...to get to the transmission and left side grounding kit I had to take off the drivers front wheel, and the wheel well liner. Did it at the same time I was putting on the a-spec suspension.
I also put on the hyper voltage kit, that was even more fun since the engine bay is so tight it was hard to find a good place to mount it, then to rig up something so it would be solidly held in place.
The trick with my kit was figuring out which lengths of wire to use where.
I would take some pics for you but my car is in the shop this week getting aligned and the a-spec body kit put on, if you can wait till the end of the week I'll take some.
Jamus22
Jun 11, 2023 10:08 AM
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
kev87a
Nov 2, 2015 07:40 AM
rhdune16
Sep 28, 2015 11:31 AM
