Comptech Supercharger Kit Special!!!
even if the pinouts match up, it might not tune the car right.... make sure you do everything pre/post dyno and you should get the HBP handy just to have in case the 4lbs pulley only makes like 2lbs (displacement difference)
Hey Sean:
Yea, i am pretty aware of all the unexpected. Using the HBP was a thought to make up for the loss in boost that i was expecting..... Do you honestly think the AEM F/IC will be able to handle everything that the comptech ACM provides the 3.2L blower?
I assumed the ACM wouldnt work, but it would be worth a try since it gets included with the blower.. If it doesnt, I was gonna go the route of a piggy-back management system. Still trying to figure out which one, but AEM F/IC seems to be the best bet for this car, eh?
Sorry to clog up your thread Josh, but if we can get closer to verifying this works on a type-s, You'll have a chance to sell quite a few of them!
Originally Posted by BLACKURA_NY
I assumed a new transmission mount might be needed, since the 07+ have the gradelogic transmission, and it might not be the same mounting spot. I will know soon enough!!
Former Sponsor
just remember that your flowing more CFM due to the larger displacement, so you might have to install a HBP to make up for the lost psi, which in turn will bring you to address the injectors, fuel system upgrade, aftercooler or meth injection, etc,.... cause lets face it, the m62 is just too small of a blower for a 3.5
there might be a way for us to get it done, swap to an accord J30 ECU and then tune that like all the other twin turbo v6 accords. Only downsides would be 1. Loss of SS for automatics for sure, and maybe a loss of other systems like VSA. This is just a guess for now...
Suggestion
For all these computer needs has any one thought of piggy backing two computers. The stock one to run the transmission and the secondary one to run the A/F and timing. I seen it before on the Older Ford Lightning F150, were the stock computer ran the transmission and the engine was run using manual Mustang computer that is MAF metered. So all the inputs that are needed to the stuck were RPM,Speed,temp,TPS, if i remember correctly. Maybe something like this can be tried or put together for a Acura.. or maybe a custom MOTEC.
navtool.com
31
Nov 16, 2015 08:30 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
polish_pat
Sep 25, 2015 12:24 PM
