Clutch Went. Anyone Go Exedy?
Old 12-17-2009, 11:33 AM
  #41
I (don't) whine.
ussi's Avatar
^Yes it incluedes the FW
Old 12-17-2009, 11:34 AM
  #42
Former Sponsor
Excelerate's Avatar
Originally Posted by KN_TL
What about the lightweight flywheel. This kit doesn't appear to include that. Or does it?
Yes it does.
Old 12-17-2009, 07:06 PM
  #43
Green Machine
t0talacuratl's Avatar
Originally Posted by Excelerate
The CM kit includes the AASCO flywheel already so you would just buy the entire CM kit.
Well.....that puts a different paint job on things! I see my next mod in sight!
Old 12-17-2009, 08:07 PM
  #44
347hp/300tq @ 4psi
04accordcpe's Avatar
Fyi, They do sell a kit minus FW. My first kit was stage 3 with the OEM FW
Old 12-18-2009, 02:14 AM
  #45
1st 3g Turbo TL-S
Xiomaro's Avatar
to be honest, there is no real gain to the LWFW. All you are doing is changing the power curve. if u like torque DO NOT GO LIGHTWEIGHT! sometimes i have to drop in at 3k or higher just to get a good run... it's kina sad
Old 12-18-2009, 03:01 AM
  #46
I (don't) whine.
ussi's Avatar
It really shouldn't, you should just be revving up faster. You're not running a lightweight pulley also are you?
This kit won't work with our stock dual mass FW, but CM does make a steel version of the FW which a little heavier.
Old 12-18-2009, 08:33 AM
  #47
KN_TL's Avatar
I would think it would have the same effect as the lightweight pulley.
Opel mentioned this in another thread that you need the mass at one end or the other. I have the lw pulley and noticed a difference so when I change my clutch, I will go with the lwfw and put on the stock pulley.
I'd rather have the solid fw instead of the dual mass.
Old 12-18-2009, 08:55 AM
  #48
Former Sponsor
Excelerate's Avatar
The kit will only work with the AASCO flywheel. Their kit will not work with the OE dual mass clutch. So yes they will sell a kit without the flywheel but it won't work with the OE flywheel.
Old 12-18-2009, 10:30 AM
  #49
All motor
Sonnick's Avatar
When I had the Exedy Stage 1 and Fidanza flywheel on my 2000 Accord 4 cyl 5spd, I was in love with it. It was slightly stiffer than stock, grabbed like a gorilla compared to stock, and is STILL going. I had about 105k when I put it on, Idk what it's at now, but I beat on that car. It then went to another owner who beat on it even more (constant burnouts, 1-2 shifts, etc.) and then a 3rd owner who continued the beating! Not 1 problem with it thus far and it has taken an absolute beating. Exedy ftw!
Old 12-18-2009, 01:00 PM
  #50
347hp/300tq @ 4psi
didnt i just say i had a stage 3 kit with the OEM FW? LOL now im a liar
trust me, it worked PERFECTLY with the OEM FW with ZERO problems
had it in my car for 12k miles, then sold it to my friend when i went for a complete kit with FW and he put another 15k on it and its still going strong
i even had it resurfaced too, when some people say that cant be done either dont believe everything you hear. the only difference between the two kits is you have to opt for the rigid hub disc (without springs) and have your FW slightly notched and your your good to go. yes, you have to send in your OEM FW for notching, but nevertheless it can be used with any of clutch kits stages 1-4
Old 12-18-2009, 01:07 PM
  #51
347hp/300tq @ 4psi
just for referrence, heres a pic of my kit with LWFW. notice the disc is a sprung hub, not rigid.
dual mass FW = rigid hub
lightweight FW = sprung hub
remember, you cant mix the two
Old 12-18-2009, 01:37 PM
  #52
Former Sponsor
Excelerate's Avatar
I wasn't call you a liar. I was simply stating what CM specifically told me. I didn't think it was possible according to the knowledge I had, which was based on CM's info. If it works great. It's something new I learned.
Old 12-18-2009, 02:13 PM
  #53
347hp/300tq @ 4psi
oh i know you werent, just giving you are hard time josh.
but i think we've all learned (at least i have) not to believe most of the bullsh!t CM shovels our way. they have some great products no doubt, but are poorly managed IMO. i'd rather have someone be straight up with me, than rather throw me some curves and try to tell me what i want to hear.
Old 12-18-2009, 02:37 PM
  #54
Former Sponsor
Excelerate's Avatar
I hear you. That's why I'm working now on my own clutch setup for these cars.
Do you know if the 3.2 and 3.5 TL share the same clutch kit?
Old 12-18-2009, 02:47 PM
  #55
347hp/300tq @ 4psi
thats a good question. ive been trying to find that out for some time now. i want to take a shot in the dark and say yes, cause i dont see any reason why they would change it. i think i might do a little research when i get some free time.
Old 12-18-2009, 02:54 PM
  #56
I (don't) whine.
ussi's Avatar
I bet you can use the same clutch disc and make some adjustments to the FW, the reason being the crank snout is a bit shorter on the 3.5 than the 3.2. The 3.5 crank i'm using is off a 03 RL and its 5mm shorter so I basically had them add 5mm of material on the crank side of the FW. I'm not sure if the TL-S uses the same crank, but it is likely.
Old 07-20-2010, 02:21 PM
  #57
All motor
Sonnick's Avatar
Any updates on how these clutches are holding up? Are there any other options out there?
I know that P2R has a high performance clutch disk available for us. However, I do not see an aftermarket option for the pressure plate (without a full kit). 1200 is a big chunk of change for that CM kit! Though I'm sure it'd be worth it.
75% of my hard shifts slip with my OEM clutch now
Old 07-20-2010, 02:43 PM
  #58
n3o
n3o's Avatar
Aren't Kevlar clutch discs amazing? I loved the one I had on my blown RSX.
Old 07-20-2010, 03:06 PM
  #59
KN_TL's Avatar
P2R seems to be the only disc option out there with the stock FW.
One of the evil's of owning a model that isn't in the mainstream yet. The prices of 3G's are coming way down so maybe the aftermarket world will pick up. But until then, it's hard to find and if you do, it's expensive.
Old 07-20-2010, 03:37 PM
  #60
hondazex's Avatar
email from jose to clutchmaster direct !!!
Part # for your application is 08-040-HDFT-S when used with our flywheel # FW-040-AL.
When using original fw , part # is 08-040-HDFT-R
this kit is for TL-S 2007-08 only
1500$ retail
this part number are not visible on clutchmaster website !!!!! weird !!
SidhuSaaB
05-30-2020 12:40 AM
knight rider
03-04-2016 08:59 AM
MilanoRedDashR
09-24-2015 11:04 PM
Quick Reply: Clutch Went. Anyone Go Exedy?
