Clutch Hydraulic Release Bearing?
Tilton twin disc is a beast to release. I can't see the stock system lasting very long if people were having problems with a CM unit even if it was due to constant pressure on the system.
Looking to upgrade at least the master cylinder but was wondering if I should step up to an HRB if Tilton can hook me up with compatible goods.
I've been reading about CMS bore size being a factor and that the pedal travel needs to be carefully set to prevent over-travel of the HRB, but I didn't see anything about it helping with pedal effort.
Anyone with HRB experience have any suggestions or advice?
My damn throwout bearing is making some squealing noises right OOTB so I'm going to be taking the transmission out again and if a HRB will help, I may just step up while it's out.
Chapter Leader (NY/NJ)
i remember reading something about a master cylinder which was compatible for our cars which reduced pedal travel by 50% or something like that.
heres the thread.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/omni-power-master-cylinder-841012/
Omni Power Master Cylinder
I don't know why it's making noises and I started pulling it apart yesterday and will have the tranny out today.
I have the pedal set with a bunch of freeplay and it doesn't make any noises until it makes contact with the fingers. The clutch also disengages, just doesn't sound good.
While I was in there, I was wondering if it would be worthwhile to go with a full hydraulic unit.
I am also going to look into getting a larger bore CMC. I'm not sure what the Omni unit is but the Tilton's have specifics. May need to fabricate an adapter plate if the mounting points are different.
My primary goal is to have a lighter pedal. Bmeyer said his left leg was getting bigger and I see why now. Driving in the city would be a chore for sure.
Found that Tilton makes a HRB for B series Honda's that fits over the pilot tube. It's the same size as our tube but I have to do some measurements of the clutch fingers to the back of the bell housing to make sure there is enough throw for it to work.
I got my tranny out and I can't see anything that could cause the noise. I thought maybe the throwout bearing was rubbing on something but the fingers have marks on them exactly where it should be and the disc isn't damaged at all from any over-traveling throwout bearing.
Bert, do you know what the throwout bearing looked like?
Does it have a cone shaped end to it?
I've done some measurements and the HRB is going to come up short. I am going to go ahead and buy it and then take it to a local machine shop to get a spacer made.
18psi
i had a huge dilema with the twin disc. ill get into detail with a pic of what happened later. theres a lot of speculation of what may have happened and still some unknowns.
basically i chewed up half the spines on one of the discs. kn, if u want, pm me your number and ill call u. i would hate for u to have the same problem. at this point, it is unknown whether or not im the only that had, or will have the problem
Got my kit today and the bearing face to finger clearance without a spacer is 6.5mm. The instructions say the clearance should be .200" or just over 5mm so I am going to give it a go without any modifications.
The heat finally broke up here so I'll be working on it tomorrow while the temps are back in the high 70's!!
Quick update:
HRB is in and reduced pedal effort by about 1/2. Still stiffer than stock but will not be as big a beast around town. I had to weld a stop to the pedal as the top switch didn't have enough adjustment to bring the pedal off the floor.
The installation of the master cylinder itself was easy because the adapter fit perfectly. I had to cut the length of the plunger to make it work. The pin to the pedal was identical in diameter. The pain was finding a location for the tank. I had to relocate my under hood fuse box to make it work.
Engagement is definitely different and even shifting gears is a new adventure but not as bad as I thought it would. Might still consider installing the flow control valve.
Running Redline Shockproof right now. The shifter is noticeably stiffer and I haven't driven enough to see if my 3rd gear issue returns.
The HRB is a pricey upgrade but it was worth it.
I finally got my car back on the road with the 6speed trans working. some how, my clutch pedal feels a lot more responsive and has less travel. Could be the Pedal adjustment and the Rsx Master Cylinder thats making my pedal much stiffer and engages the clutch with less effort.
Finally getting some time on the twin disc and still getting used to the reduction in rotational mass and the on/off characteristics of this clutch, but with the HRB, it makes it so much more drivable.
I was worried that I was going to hate driving it with the new clutch but I am changing my mind. If you can afford an extra $500, it is a worthwhile change.
On the other hand, I am experiencing 3rd gear misses with the RedLine Lightweight Shockproof.....So I'll have to decide if I want to go back to the GM stuff or do a gearset replacement.
I'm not sure what I want to do at this point. I may hit you up if I need something.
1st 3g Turbo TL-S
Did you do anything to the used tranny that you installed? I am one of the lucky ones who probably could use the 3rd gear TSB but it's not so bad that the dealer will address it. So if I do anything it'll have to be on my own.
Hmm if you have freeplay the TOB shouldn't be making any noise. If it started grinding then it's too late and it's gone. Mine was making noise for a while and I had the pedal readjusted again which made it go away. I'm not running a twin disc setup but I'm running the clutch masters fx300 clutch
breaking in period sounds like its almost over for mine, chatter and squeaks but its not bad at all. everythings holding up good and its super easy to drive. might look into this hrb... might, ive been driving daily and in traffic and still love it.
KN_TL got any issues with first gear? minor issue, first popping out on a level throttle (minor = happens maybe 2 times a week type of thing)
SidhuSaaB
05-30-2020 12:40 AM
