clutch
clutch
anyone replaced their cluth if so what kind of clutch did u replace it with. i have a 04, obvious its manual... and what did u replace when u did replace your clutch with any suggestions?
Registered Member
Well with only 64,000 miles on my '04 manual, my TL is hardly even a bit close to a clutch replacement. I'm perhaps 1/4 of the way there and maybe less. Hard to imagine a manual that has been driven normally in non-extraordinary situations and has a good clutch system to begin with having to replace the clutch in such a short time.
http://store.nationalspeedinc.com/in...th=10026_10030
im about to order the stage 3
The Kinetics of Bleu
http://www.lmperformance.com/45623/104.html
I had SPEC clutches before both in my blown and stroked Camaro and in my Turbo Escort. Never had any problems with them...
347hp/300tq @ 4psi
yes they do and every one of them is garbage
they simply paint an oem PP, coupled with your choice of disc material and try to pass it off as a performance clutch kit
trust me, i bought one and sent it back. they gave me a hard time, but i received a full refund in the end. STAY AWAY FROM SPEC!!!
347hp/300tq @ 4psi
Originally Posted by TLAdvanced
WOW! That sucks if that is the case. I had a Spec stage 3 on my blown and stroked Camaro with 480rwhp and never had one problem with it...
i have the type s clutch in my 05 6mt.... theres no diff in clutch and pressure plate...from what ive noticed when it came out and the swap was done. The flywheel may be different because i know the bell housing on the Type S was changed....the throw out bearing blew my replacement clutch and im waiting on seeing whats good with a great oem replacement from another company or just dealing with the same old junk shit from honda.
im still wondering if the comptech unit from the cl-s would fit in this car? I dont know if im going to keep my car but if do i want that unit in there. i drove an s/c cl-s with the comptech clutch and i loved it. very smooth and solid engagment with only a little more pedal force required.
347hp/300tq @ 4psi
my clutchmasters flywheel is from a cls and has the slots where the crank sensors go.
Former Sponsor
If you're looking for a clutch kit with flywheel Clutchmasters is pretty much your only option right now. SPEC does make clutches for the TL but no flywheel. We're in discussions with a company who will be making a setup and it should be priced below $1,000. They've been dragging their behinds for a number of years on this kit but I have gotten word recently that they have actually started test fitting it on the Accord V6. So hopefully we'll have another option soon. I will post more details when I have them and that is all the info I have now.
jwong....honda makes shitty tranny mounts anyway lol... i just want something thats a little harder than whats there now and i want it to grip quicker on the pedal release....if thats possible to do from just a clutch kit.
SidhuSaaB
05-30-2020 12:40 AM
