Changing Cold Air Filter
What would be the easiest way for me to change my aem filter? jacking it up? my car is slammed with no wheel gap so im not sure what to do. im pretty lazy.
I have car ADD
k..
when you are slammed.. you need to drive up on like 2 or 3 pieces of wood. 2 x 4's work best ...then jack up the car (its the only way i can fit my hydraulic jack under a slammed car)
remove the front left wheel, take out ...3 plastic clips, and 2 10mm bolts fron the bumper and lining.. and pull the inner fender lining outwards... then unscrew the filter, and replace!
94 DC4 RS LSV/Turbo
^ on the money, if you would like to remove the entire tube to clean the inside (which I think you should) it will require quick removal of the battery)
best way to clean the inside of the tube is with a detail towel or any other clean towel you have lying around and just push it through, you will find dust in there so do it
If you just gonna turn the wheel, no need to jack it up. You can get in there and remove the clips and bolts that secure the wheel well on and get to the filter without removing the wheel.
HydrasunGQ
09-14-2015 10:14 PM
