CEL code after Cold-Air installed on my Type-S
I recently installed an AEM intake on my TL-S... well, I got a check engine light.
The code is 0443: Purge Valve C Fault
Anybody have ANY IDEA why that CEL is coming on? I know 100's of people have this intake, even on the new Type-S, without problems. I would love to fix this myself, since I'm sure the dealer won't be any help.
Thanks guys
Matt
Thanks guys
Matt
Originally Posted by Chriscapo
this is on an 07? same thing happened to me . AFTER i moved the sensor from the T/B to the pipe... Just disconnect the negative side of the battery for a full 5 mins then try it
I installed mine this weekend and didn't have a CEL until after I moved the sensor. I did the battery disconnect for 10 minutes and the CEL went away.
It's at the dealership right now getting the suspension TSB taken care of - we'll see how that goes...
Originally Posted by jonathan.chance
Same thing happened to me...
The IAT sensor. Did you move the sensor from the upper manifold/throttle body area to the intake pipe?
I didn't move mine at first and had no check engine light. I decided to move it a couple of days later and that's when I got the CEL. The sensor is the one that was referred to as the "Optional Power Adder" in section 4 of the AEM Intake installation instructions.
Got it... didn't know if you pulled the code from the diag screen or with a diagnostic computer/chip. Sorry I can't be of more help. One a side note - when we installed my UR pulley I threw five or six diagnostic messages; that was back in May and my car is still running fine. I have no idea how to clear those navi based messages. I've tried but no success. Maybe someone else can throw us a bone?????
Good luck.
Good luck.
My Garage not
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
u have a leak in your evap system. ie...one of the hoses has a leakage that expels burnt gas and other waste fumes which are spit out of the exhaust. the evap system can detect a pin needle size hole in the hoses.
Originally Posted by mattbizkit
the sensor that you are suppose to move to the cai, what's the difference from moving it or leaving it in the stock position?
