Can't leave well enough alone. New BIG oil filter.
I'm currently running the Amsoil EaO20 filter for the S2000. It's bigger than the stock TL filter but still small. Since we have tons of room in the filter area, I got to searching for something bigger. Found the EaO36. Same threads, same o-ring diameter. Same OD as the bigger Eao20 filter and 4.72" long vs 3.39" for the 20.
Seems like a nice increase in filter area over stock and a few extra drops of oil capacity. For the same price, why not?
Originally Posted by stillhere153
Why not just use a hamp filter instead....
Originally Posted by KN_TL
Does this change the oil pressure?
Hamp also sells mini oil filters that are supposed to raise the oil pressure for protection at higher revs. Assumption that larger would have the opposite results.
I can tell you for a fact that on my other car with an actual oil pressure guage and the sensor being after the filter as it should be, a bigger filter definately raised pressure by a few psi. It could be extreme because that particular car had nearly 100psi when cold but the point is the big filter definately did not lower pressure.
With the bigger filter and less restriction, there would be less chance of the bypass opening, especially when cold, and letting unfiltered oil through the motor. This filter also has the higher psi bypass valve like the S2000 filter. I realize our cars use very light oil and the filter probably isn't that big of a restriction but if you can get a bigger, better filter for the same price, why not?
I see your point, so I guess you'd also be running 5w30?
the 5-20 is a scam to meet CAFE standards- the engine likes 30 just like it always has
I definately come from the old school way of thinking but stay open to new ideas. My GN runs 20-50 dino oil. What I've been told is that in the old days thicker oil protected better because it was used as more of a "barrier" between parts. Thicker oil was harder to squeeze out from between two parts. With the newer oils, they're supposedly "more slippery" for lack of a better word with better additive packs, and no longer requre the viscosity.
My reason for going with the 30 weight is because with the slightly higher temps than most of the country, my hot viscosity was probably close to what people with the 20wt see in cooler climates and the startup cold weight is unchanged.
What I will say is that the valvetrain noise the car (and every TL) has had since day one went away with Amsoil 5-30 but not with M1 5-30. Does less noise mean less wear? Not sure but I will be a life long Amsoil customer.
IBankMouse
06-13-2020 12:53 PM
STL TL-S
09-23-2015 08:52 PM
