Calling all honda part number experts to help!
I have a build I am doing that I need some expert help with. It doesn't directly have to do a 3rd gen TL but in a way it does. I am wondering if there is any difference between the rear diff on a acura TL-SH AWD between the auto and the manual transmission. The final drives are different on each transmission so I would think that the differentials have to be different.
Auto is: 4.533 final drive
Manuel: 3.842 final drive
With I different final drive they must have different rear differentials but both have the same part number:
41200-RWG-080
Then I thought they have different transfer cases but they have the same part number:
29000-RK4-000
Then I thought well maybe they have different output drive gears to the transfer case but they don't. Both are:
29200-RYF-000
So do I just not have an understanding of how this should work? How can the auto and manual have different final drive ratio's yet use the same rear diff? This would mean the front and rear wheels would travel different speeds and the rear diff would burn itself out fast.
What am I missing here? Does the final drive gear ratio not matter?
So here is the 3g TL question. Are the bell housings the same on the J35a8 motor and the J37 motors? Meaning could you bolt a transmission from a J37 to a J35a8?
41200-RWG-080
29000-RK4-000
29200-RYF-000
yes, but Is that wider bolt pattern the same on the 07+ TL's?
first off, why would the differential be different between auto and manual?
final drive has to do with the gearing INSIDE the transmission. final drive only determines what rpm the engine will be turning at relative to the wheel rotation. Not sure why you thought it makes a difference, the differential is only spun by the transmission, and the gearing is irrelevant.
http://www.locostusa.com/forums/view...hp?f=35&t=2664
darksky
09-05-2015 03:11 AM
