Acura TL Builder's Ultimate Boost Thread
#405
no idea...
i'm implying that it's picking up a higher psi somewhere before it gets shoved into the engine...what I would presume is a leak...I'm picturing a leaking valvestem or something...be easy to make 5 extra psi on a sensor or something.
#408
Nope. They have been clogged. My car now sounds so quiet it’s eerie.
im going to gut them this Saturday morning. I have not yet turned on the meth/water system because I’m going to first finish my tune.
I’ve contacted Andy Gerzand and if all goes well will order the Stage 3.5 kit. Though it will take four weeks to arrive because he’s going on vacation.
#411
Latent car nut
Received 2,005 Likes
I just had a thought; could the spike in boost be due to either floating or leaking intake valves?
#415
I’m driving down the highway, going home from work. “When out of nowhere” I hear a thwap, thwap, thwap, thwap. My heart sinks and the first thing I think is, oh got there goes my engine. I quickly pull over and shut off my engine. Pop the hood and find serpentine
belt ground up between the blower pulley and neck. I spend a few minutes
pulling out strings of serpentine like spaghetti while cars are zooming by.
When i I was installing the belt I tried to make certain the blower support pulley was in tight. But first I wanted to unscrew it. So I began turning it like a standard bolt and thought, wow this sure is on tight! After some wrenching I hear a pop and a little give. It was loose now, but 1/2” off the track path. So the new serpentine belt was but to that size by the off track pulley. Is there a way I can fix this pulley?
#419
Just misaligned. It’s not the main blower pulley, it’s the supporting one.
There was luckily no damage from the belt tearing.
Acura TL Builder (07-13-2018)
#423
So the CLS power steering inlet did not work?
More than likely, your 'shaft' end pulley is slightly out of alignment because you are using an improvised 'set-up' at the alternator end. The one engineered by CT would have placed the blower shaft in almost perfect alignment to minimize any misalignment. Just keep trying to get it aligned the best you can and, for the time being, buy and have on hand an extra serp. belt for contingencies like this.
#427
Anyone have an idea as to how to gut the cats? I tried to use a bar and a hammer and it’s not working as well as I thought. I could try to drill it out with a large bore drill.
Since the 3rd cat is unaffected. I could replace the precats and just drive it until it clogs again. Then unbolt the 3rd cat and keep cleaning it out until it’s all gone from the precats? Seems like the easiest way to do it.
#428
Check your egr passageways in the head and in the EGR valve and runners. May have sucked some into the intake and maybe cylinders. It seems the HFPC's have a high rate of failure, boosted or not. Sorry to see that man but glad you've got plans on the horizon.
#430
Mike, I love your build man. I hope you will be there to give me pointers when I go to install the 3.5. Andy is getting it ready. Since I live so far away I’ll have to install it myself.
#431
zeta (07-15-2018)
#433
The WOT cat gut trick seems to be working, I floored it and heard a bunch of metal sounds in the exhaust. Going to clean it out of the “third cat catchcan”. If this works I can save $400.
#435
I’ll message him about it. I just got another load of cat material in my 3rd cat. Car barely started before I headed home, so that’s a good sign that it’s ready to be emptied. Soon enough, Ill have the only RV6 HFPC PCDs around!
#436
Hopefully that solves the problem. If, in a little while, you find the belt wearing again, you may have to engineer a little vertical "up & down' adjustability into that improvised alternator connection, time will tell.
#437
Acura TL Builder (07-27-2018)
#438
Car is running good now. I gutted the RV6 HFPC as I wait for my RV6 PCDs. Car isn’t running 9psi anymore so it’s not as fast as it was. Though it’s running healthy, I was getting worried.
I used a 3/8” electritioms 2x4 still and beedlenose pliers to get it all out.
What difference would the gutted HFPCs HPwise vs. the PCDs? The only downside I can imagine is air turbulence.
#439
