Blue's custom Type-S intake!
Just finished up my custom intake for my 2008 TL Type-S.
Well, i've had this Apexi Power Intake filter lying around forever, figured i'd try to do something with it rather than just selling it. The Apexi Power intake is the BEST rated filter on the market, it's pricey, but sucks like hell! For this mod, you'll also need the 80mm cast bracket that is pictured and attached to the filter.
Anyway, i'll explain this quickly and simply, the result is a great / stock like look with a very throaty growl and explosive VTEC cutover. Power and throttle increase seem to be improved, not by a whole lot...but enough to notice. Under low to partial throttle it's dead quiet!
- Pop off the top of the intake box, attach the Filter with Bracket to stock intake piping, use a 4" hose clamp to secure.
- I used a small but of foam on either side of the filter to keep it snug and prevent rattling, push the filter down into the bottom part of the intake housing as shown in pic 2.
- Determine the best way to hack apart your filter cover, i used a dremel, then patched it up with some real carbon fiber stuff i had lying around, one side is adhesive. I then used some weather stripping to cover up the edges and some foam on the inside to clean up the look. You can see the finished product below..it's not super pretty, but the best i could do with what i had...i also cut off the left hand portion of the intake cover and cleaned that up with the dremel so I could re-attach the wireloom (not pictured). This part is up to you, so have at it.
- Install everything back up and enjoy!
Apexi filter intalled:
Again, pushed inside the bottom intake box
Customized air filter cover
Another pic of the filter cover.
Filter cover installed
Another shot
Engine bay, nice and clean!
Another shot
i can't stop ripping around now...i went from averaging 21 mpg around town to 13mpg! lol, i need to chill out with redline rips, this thing pulls STRONG now. The noise is just music to my ears...not too loud, but very throaty and mean!
two thumbs up!
two thumbs up!
2007 A-Spec Type S
Blue Rocket that is sweet! I thought my DIY CAI was a clever mod. Yours looks great...and a short ram air with conical filter is the best most effective way tho get the most air, fastest to the intake. Good job.
So your engine is breathing air that is ridiculously hot inside the engine compartment? I don't really see how is going to increase performance. It looks pretty cool and you used something that was collecting dust...but I don't get it.
all SRI type intakes take hot air from the engine bay. The only intake that made a difference on my previous Si (K20Z3) was a short ram intake using a slightly modified MAF as well as the Apexi Power filter.
Ultimately you are using a MUCH better filter with increased airflow from the stock filter, so the car and breath easier, the few degrees difference in hot air may negate the power from increased flow. What i'm seeing is absolutely no loss in performance and a much nicer sounding car!
Agreed that it would be even better to fully seal off the filter box, but it's not possible for me as i have no way to fiberglass the enclosure. And there's no way that the filter cover would fit over the Apexi filter as it's too wide. The car still should suck in some cool air from the factory cold air resonator under the car.
I've never been a fan of CAI's as i ALWAYS feel like i lose throttle response.
2007 A-Spec Type S
The only real air cooler is NOS or meth injection. I ran a water/meth system on my STi...it cooled the cylinders and engine considerably....creating an extra 20-30 hp.
I agree that everything in the engine compartment does get very hot. Even the CAI housing under the hood. However, unless one is driving at minimal amounts of throttle, I can't imagine the air having sufficient time to heat to the same under hood temperatures. The air is being moved through the intake tube far too fast. A great deal of heat is transferred into intake air through the plenum/intake manifold and thats why we have mods like thermal spacers and the coolant bypass DIY to help fight this heat transfer.
i'm not into hacking apart my car to push more air in there...but so far, so good with the setup i'm rocking...i can tell even after 30+ mins of driving there is no heat soak as i get a LOT more wheelspin when accelerating from a stop.
i havent driven a type-s with a CAI, but so far i'm completely loving this home made intake!
thought i'd give an update after driving with this thing for a few weeks.
Not a single side effect, no changes in idle, smoothness, hesitation, anything! First gear will now get the tires spinning if i nail the gas at 4500 rpm, never did that before. Highway pulls seem stronger and overall performance seems crisper and stronger. I would honestly say that this had to have bumped the HP / TQ at least 8-10.
I've gone on a lot of longer drives and have not notice any heat soak or loss of power. The sound of the car and the performance gains from this have been great, i couldnt be happier. For anyone who wants a low-profile intake, i would highly recommend the custom apexi SRI.
NOT my TL or ME
Even if you have a CAI collecting cooler air from the outside...by the time the cooler air reaches and goes through the intake it heats up considerably...making little difference. The only exception is at first start up, but when an engine is warmed up...everything gets very, very hot.
im getting cold air fed into fender well via ramair through A symbol in the grill and it doesnt have an opportunity to heat up due to the excess air flow charging into engine bay.
actually runs cooler now.
it isn't the A symbol by looking at your photos. It functions by taking in air from the driver side lower grille and then feeding it into the engine. That isn't a Short ram intake... As well the air is going to heat up. The aluminum pipe you are using is basically absorbing the heat and then heating the air as it travels though. If you insulate it and make all the piping aluminum insulated, you will see measurable differences in temp.
2007 A-Spec Type S
If you run your car...for an hour...to normal running temperature. And, pull over, pop the hood...if you can place your palm on the intake manifold WITHOUT burning your hand. Then, I'll believe you. Even touch your airbox, air duct....HOT!
Only in the morning at first start up (when everything is cold) or extremely cold air makes a significant difference. But, don't misconstrue my initial post...CAI make a difference. Just not a lot.
NOT my TL or ME
Please....internal engine temps are extremely high. Outside air is not running your car cooler. What AFTERMARKET gauges are you looking at? OEM dash lights...please?
just walked in the door from driving about 2 hours and my temps on and around the block is almost 20 degrees cooler than my average pre-forced induction temps. ran approx. 70-110 for drive.
i have no airbox, but custom short ram is warm to touch .... not hot.
its not the cai that made the huge difference, but the ramair. i really didnt even see a temp change after cai.
NOT my TL or ME
[QUOTE=blue rocket;10023694]all SRI type intakes take hot air from the engine bay. The only intake that made a difference on my previous Si (K20Z3) was a short ram intake using a slightly modified MAF as well as the Apexi Power filter.
Fiberglass you CAN definately do.
I see your skill, but either way, I LOVE YOU!!! you have just given me my intake. I am going to invert it in the wheel well tho.
Thanks again!!
Skillz
Thanks again!!
Skillz
NOT my TL or ME
i agree that everything in the engine compartment does get very hot. Even the cai housing under the hood. However, unless one is driving at minimal amounts of throttle, i can't imagine the air having sufficient time to heat to the same under hood temperatures. The air is being moved through the intake tube far too fast. A great deal of heat is transferred into intake air through the plenum/intake manifold and thats why we have mods like thermal spacers and the coolant bypass diy to help fight this heat transfer.
NOT my TL or ME
just saw this, sorry for the delay....
u need a pic? wonderful.
assembled or dissassembled????
how about i shoot my grill off the car.....
be back in 10 with a pic
NOT my TL or ME
My bad, it took me like 20min just to type this......
No disrespect csmenace, but I neither have the time nor the desire to lie on an internet forum (if your implication was such), but I do understand you deal with misleading bs all day..... bothers me tho, so here ya go
so I'm entertaining the possiblity that you are just curious....
plus im a DON, so my swagga neccesitates me posting these pics ....
Gosh the front of my car is filthy (due to excessive driving and extremely busy elective surgery season)
Here is a pic of my front bumper stock air induction, O, my bad nope its the A symbol from the grill.... thick enough sarcasm?
Here is the ingenious part.... treaded link into the funnel to allow airtight fitment and the necessary strength needed at 100mph+ speeds
Cleanliness on this portion of the mod is irrelevant here due to the fact that you can not see it and since now I will be doing a totally different grill design... I am excited to post as soon as it is complete!!
and finally... assembled hose to custom fab'd airbox (not complete or all my pics would have been posted)
NOT my TL or ME
I was reading up on the ability for forced induction in this situation to be able to cool a motor.
To be honest, I didnt believe it (thinking to myself more dense air = hotter combustion = hotter motor) hence the need for another method of cooling.....
Anyway, the guy who wrote the forced inductin paper was right. It actually cools the under hood temperature .... well on a 3G TL at least.
no offense taken, that is a pretty cool mod, have you though about retrofitting the 07+ acura symbol, that thing is huge, you can fit you hand through the sides, and thus more air. Quick question though, how did you route the piping?
B A N N E D
[QUOTE=csmeance;10283870]no offense taken, that is a pretty cool mod, have you though about retrofitting the 07+ acura symbol, that thing is huge, you can fit you hand through the sides, and thus more air. Quick question though, how did you route the piping?[/QUOTE]
Yes, I am very intrested in that also. where does the hose end up?
AZ Community Team
Received 7,771 Likes
[QUOTE=UAwalker808;10284736][QUOTE=csmeance;10283870]no offense taken, that is a pretty cool mod, have you though about retrofitting the 07+ acura symbol, that thing is huge, you can fit you hand through the sides, and thus more air. Quick question though, how did you route the piping?
x2
practicing nihilist
I remember pushing the 'I Believe' button on a previous CAI thread discussing ram air effect. Unless the air is actually being compressed, the engine is only going to ingest the volume of air that it needs.
I know there are some aerodynamic effects that will compress air as it would travel through that tube, but to my knowledge these happen at very high speeds, speeds greater than most of us are traveling routinely.
