Blower surge, CEL FIXED, YAY!
Well after fighting it and fighting it...my blower surge and CEL issues are finally fixed.
Ever since I did my blower install I had the dreaded blower surge as the car went from closed to open loop and lately I've been getting knock sensor circuit codes. The surge got so bad it was like driving with someone learning to drive stick and I would just have to pedal through it. Embarassing.
Well, after talking to Comptech they said that while the instructions say to cut the knock circuit so the AEM can filter it, they never actually modified the knock data. Meanwhile my AEM's knock filter was perhaps bad. Putting the red/green knock circuit wires back to stock as recommended by Comptech (leaving the rest of the AEM install alone) fixed my problems 100%.
IOW, you don't need to cut the knock circuit wire for the blower install and the person I spoke to said they intend to update the blower install instructions to reflect this.
So anyone who is getting knock circuit check engine lights or abnormally bad blower surge may want to try putting the red/green wires back together. Comptech said it fixed a few problems they've heard of and now it's fixed mine.
They also mentioned that they're working with HonData on changing the point in which the cars go from closed to open loop to be rid of the small surge that is left. Good news for us blower folks.
Glad you got your problem fixed. I haven't had a single CEL in the year since I installed the blower. Also, my surging isn't that bad. It's there, but only sometimes. Bring on the Hondata Reflash! I tried to get it last year and got the run around. Hopefully it will come out soon.
I believe what surge that I have left is like yours now...there but not "bad". I have a scan tool and I can see when the car goes from closed to open loop and the surge happens just as it changes. So if Hondata can move the closed to open point the surge would definately go away completely.
OOOOOHHHHHH
Good news, it will be interersting to see if Comptech and Hondata can come together and tune the ECU to work better with the charger. If its done right may be more HP can be gained with the charger.
wow....so you have been boosting with no knock sensor? Did you audibly hear any knock(sounds like marbles bouncing around in a tin can)? i surely hope you didnt run it hard like this.......
So Comptech forgot to state that the knock sensor wires needed to be reconnected....wow. especially since their "ACM"(nothing more than a simple MAP clamp) releys heavely on the knock sensor to provide ingition timing retard in boost.
Im suprised you didnt have a major detonation event due to this.
Either way, glad to see you got it worked out before you did have a major detonation event.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
CJ
CJ
CJ
CJ
CJ
According to the tech I spoke with at Comptech, the AEM doesn't modify the knock sensor circuit at all and recommended returning the knock circuit to stock (rejoining the wires).
They didn't "forget" anything. Originally when developing the kit, they routed the knock circuit throught the AEM in case they needed to modify the signal. Turns out they didn't need to modify the signal but never bothered to change the instructions removing the step of intercepting the knock signal. However under some rare circumstances, some customers like me have had problems with the AEM knock filter causing these major problems.
wouldn't be easier to fix the suging by using an e-manage ultimate thingy to fix it all?
The Boss
![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
oh no........ more hondata shit LMFAO. No offense Dan, but Hondata is just retarded in my book.
One on the right for me
I like my reflash. I'm sure you'd like yours as well...
its obvious to me that some of you are oblivious to the Honda world. If you only knew or cared about what Hondata has done for the Honda performance world, you would not even think such nonsense.
You should really do some research before you blurt out garbage like that.
CJ
CJ
with the acm for the comptech supercharger just to make sure it does not modify how the knock sensor works? what does the acm modify exactly? just to clamp the voltage, modify the fuel output??
The Boss
CJ
CJ
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Like I said, I can careless about the surge problem, this is a car that I need to boost for daily driving. It's enough power and I'm only keeping this for another year or 2 before I purchase my corvette. I mean........ lmfao...... it doesn't take 2 focking years to reflash a supercharger does it?
OOOOOHHHHHH
Oh I know what Hondata has done for Honda world. You see.... having a good reputation is one thing but failure to produce for a product that a section of the forum requires is another. But what have they done for Acura (TL)????? 2004~2007 to be exact? :cricket: exacccccccctllllllllllly........ ![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Like I said, I can careless about the surge problem, this is a car that I need to boost for daily driving. It's enough power and I'm only keeping this for another year or 2 before I purchase my corvette. I mean........ lmfao...... it doesn't take 2 focking years to reflash a supercharger does it?![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
According to the tech I spoke with at Comptech, they had intended to have the ability to change the knock sensor signal but ended up not needing to. The knock sensor wire (red and green I think) does not need to be spliced through the ACM.
Originally Posted by encrypted03
Has anyone else actually tried this on their ACM? I'm on my 2nd one, and I'm afraid to screw w/ it till I know for sure this thing will work ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I'll give them a call later this week, but when I had the same problem w/ my 1st ACM, they told me I need to buy a new one. The only issue I'm having with this ACM is the surging.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I'll give them a call later this week, but when I had the same problem w/ my 1st ACM, they told me I need to buy a new one. The only issue I'm having with this ACM is the surging. ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Putting the knock wire back together so that it was stock "magically" fixed every problem I had. It was like driving a totally different car. I cleared the knock circuit error code that was triggering the check engine light and it hasn't come back.
I would put the knock circuit back to stock. It won't hurt according to Comptech; it can only help if it's the knock filter in the ACM causing your problem.
The surge you guys speak of is not a good thing. It is directly related to bad tuning. Something is not right. May be the closed open loop issue. Which is a huge one. i would know more if i could get ahold of a S/Ced TL in my area for testing.
CJ
CJ
Blown is Best
Maybe? deffinatly! Competech deciding to go it alone was a bad move and has been talked about as such for awhile now.
CJ
CJ
check my other post about hondata. I will be the 06 test car since my supercharger will go on soon, and so after doug owner of hondata will test it out on my car. soon after should be for sale. so no more surge etc
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
