best sri for tl-s?
best sri for tl-s?
i have 07 tl-s and want to replace intake but the place that im leaving here, there's ranny and snow at winter season. so i think im gonna get short ram intake and i wonder which brand is good for my car. please give me any sugggestion. thanks.
when will the madness end?
just keep your stock intake. don't change something just because you can. often times, adding all these extra parts may give you some more power, but you'll also be running richer and w/out a proper tune you'll end up with problems down the road. you won't know it right away, and your car may sound "mean", but the car is designed a certain way and all these modifications aren't always a good thing for your car to have to deal with.
that's just my opinion tho, feel free to do whatever you'd like man, it's your car after all.
Chapter Leader (San Antonio)
i'm saying if you want to start modding your cars engine, then find yourself a good tuner. get a nice baseline laid down...then everytime you want to put anything else on the car, come back to him. have him adjust the tune and check it on the dyno (or street)...this will cost more $, but it is the proper way to modify your car, and leaves the smallest margin for something going wrong (which would lead you into a fight with the warranty company-and they will fight any claim you file. If your car is modified in anyway, the chances of them deneying your claim goes up a lot.
i'm just saying do it the smart way...don't try to go cheap on engine stuff. people that do that almost always get bit in the ass down the road.
again, i'm an idiot. anything i say is not true. i don't even own a car or a computer. i'm at the library right now.
For what it's worth, SRI was my first mod. Now i've got a full exhaust and crank pulley, and put the stock airbox in. I didn't really notice any change in power, but throttle response went down. The SRI really helps with throttle response.
no. i guess i kind'of went off the handle with that statement. it didn't really apply to a simple intake. i should've explained i was getting into a more complex subject. forgot a sentence or 2 there...
I think you're under-estimating our ECUs ability to adjust. Let's just take for example, a TL in Cali at sea level and a TL in Colorado (mile high). The ECU will need to adjust for the differences between air input. Same applies with a simple cold air intake. Once you go outside the range of ECUs parameters (IE... Forced Induction) is when I believe your statement is completely valid.
I'm in no way calling you and idiot or stating you don't own a car or computer.
but just wanted to throw in my two cents. I think you're under-estimating our ECUs ability to adjust. Let's just take for example, a TL in Cali at sea level and a TL in Colorado (mile high). The ECU will need to adjust for the differences between air input. Same applies with a simple cold air intake. Once you go outside the range of ECUs parameters (IE... Forced Induction) is when I believe your statement is completely valid.
but just wanted to throw in my two cents. no. i guess i kind'of went off the handle with that statement. it didn't really apply to a simple intake. i should've explained i was getting into a more complex subject. forgot a sentence or 2 there...
i don't know anyone that can tune a TL. i've read up about the ECU in TL's, something about them being hard to crack into. i've also read about hondata reflash/flashpro. all of this is subjective tho bc the fact remains that your tuner can still damage the engine with an improper tune. it is risky going with these methods. i don't have any passion for tuning my car, i don't even know why i brought it up in this thread lol...
i guess TL's arent looked at as engine work cars. most TL's are driven by the older crowd, bone stock, a-TO-b days.
if one of these companies would realize the potential their ECU trips could have, they'd have a lot of happy customers. well, at least most of us here at azine.
Do any of you modification haters have any dyno sheets supporting your claims of LOST power by adding an intake?
If not, then I suggest one of us do it to end this madness, a part of me does not believe the loss of power from adding a better breathing intake whether it be short or cold air. I do understand that warmer air is not optimal, however allowing the car to breathe better will make more power.
Although your very negative comments are not constructive how about someone send me an intake short or cold or both and ill pay to have all three dynos done, and send the intakes back.
Its just sad that there is so much opinion floating around without any hard facts. Just because some internet bully with a bizillion posts on acurazine says something will make or lose power does not make it fact. That makes it opinion.
Summary,
research, test, on your own, and take everything on here with a grain of salt that most of these people are telling you. Cause I bet you most are wrong.
Summary,
Although I do agree with his advice on dynoing the car to confirm power increase, which is what I have been preaching all along.
Tunning your car is to squeeze the optimal performance out of additional parts added, you will still pick up power by adding these said parts without tunning.
If intakes made cars lose power then prove it, other wise you just sound like an ass.
MetalGearTypeS
Aug 29, 2016 08:28 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
